Help ID hose in picture.
Old 05-08-17, 01:29 PM
cbavoukian
cbavoukian's Avatar
Default Help ID hose in picture.
Hi, Newbie here. I just bought a used 2007 GS350, after reading the threads, I took a look at the water pump and saw a lot of pink fluid. I think the source is the hose, can someone help id the part? Also a bit of plastic broke off, is it important (blue arrow)?
I'm at 107,000 and going to attempt the water pump replacement. What else would you recommend to do?
Old 05-09-17, 02:27 AM
Sodium
Sodium's Avatar
Welcome to CL, and congrats on the car!
Yeah, definitely looks like it needs a new water pump badly! Here is a diagram of the coolant system, http://www.lexussouthatlantaparts.com/showAssembly.aspx?ukey_assembly=1175302&ukey_make=1082&ukey_model=15660&modelYear=2007&ukey_category=21746&ukey_driveLine=8073. Looks like the hose you're indicating is 16267 at the bottom left of the diagram
And while you're in there, you may want to also replace the thermostat
And I wouldn't worry about the plastic part if only a little bit broke off
Old 05-09-17, 01:32 PM
cbavoukian
cbavoukian's Avatar
Smile
Thanks a lot! Looking forward to being part of the community.
thetrevste
Performance & Maintenance
18
05-31-21 08:00 AM
SharpGent
02-19-19 06:49 AM
ch1llwill
08-07-10 06:05 AM
Quick Reply: Help ID hose in picture.
