Newer Model Wheels Fit 3GS?
I'm new here, but a longtime 2007 GS350 owner. I have the original chrome 18" wheels on the car, but I'm interested in replacing them with newer 19" wheels. The ad doesn't have much info, so I'm not sure on the exact size/offset of the wheels, and was hoping someone could get them identified and tell me if they'll fit my bone stock car. I appreciate the help.
https://daytona.craigslist.org/wto/6096731985.html
currently have those exact same wheels F-sport 19s on my 2008 gs350. i believe the fronts are 19x8.5 on 235/40/19 and the rears are 19x9.5 265/35/19. fit perfectly fine. my car is lowered and there isnt any issue. can upload some pics if you want to see how it looks exactly on the car
naw i dont have any spacers for my setup. my car is dropped about 2inch in the rear and 1.5 in the front. i have been told that i can put a 15-20mm in the rear and 10-15mm in the front and i should be fine. but my rear fender has been shaved. the front i didnt do anything to it.
BC 'slightly' lowered with 19" fsport and rear spacer
OEM with 4gs 19 f-sport
Pretty sure I had a 20mm spacer in the rear, but wanted a 25mm in the rear. Around 2.5 camber all around. I did run a stretched tire in the front. Good luck with a 20mm spacer in the front, I think you will hit the fender liner. With my setup, I had a few spots rub away on the fronts. F-sports are STRONG rim.. (Let me know if you want to see some gs/f-sport carnage)
