Help, torque specs for endlink/wheel hub
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Hi guys, I'm trying to change my REAR endlink, endlink bushing, and wheel hubs.
Could anyone provide the required torque specs for REAR swaybar endlink, REAR swaybar bushing bolt, REAR wheel hub bearing torque, REAR caliper bolt torque??
I've been searching all over the internet, please help! much appreciated.
AWD 2006 LEXUS GS 300
Welcome to CL!
Endlinks: 66 lb*ft
Swaybar bushing: 24 ft*lb
Wheel hub bearing (4 bolts): 52 lb*ft
Regarding the rear caliper bolts, there are two different torque specs. For the bolt with one line that goes about halfway across the bolt head the torque is 40 lb*ft, and for the bolt with two parallel lines that go all the way across the bolt head the torque is 48 lb*ft. There's also a third, smaller bolt that has a torque spec of 18 lb*ft
Endlinks: 66 lb*ft
