07 gs350 no start
Old 06-11-17, 11:39 PM
Jdub82
Jdub82's Avatar
Default 07 gs350 no start
I just started my car and I made a weird grinding noise like when you try to start a car that's already running, it started after the grinding but now after I killed it and tried to restart now nothing but a slight buzzing sound. I'm thinking maybe a starter, i checked the battery voltage and its at 12.45v ,I've searched the forums and can't find anything on the starter location to try and bump it and see if I can get it to disengage and maybe start. Would love a DIY guide our any input on suggestions, thanks in advance.
Old 06-12-17, 11:45 PM
aneidiaz
aneidiaz's Avatar
I have no clue what it may be exactly. But sounds like it's most likely the starter. When you try to turn your ignition on a key car that's already on, that's EXACTLY what it sounds like lol. I know from experience smh. Maybe you can go on mylparts.com and look up a diagram. Look up the starter for your car and study the picture. Best advice I can give you. That'll help you imagine and locate the starter then you can attempt tapping it or changing it from there. Good luck bro I hope your problems are less then what your anticipating and that your on the road asap! GodBless!
Old 06-13-17, 01:23 AM
tcr101
tcr101's Avatar
If it started the first time with a loud grind sound, i would consider the battery. Try to jump start it and see if its fixed. If it starts and the grinding sound is still going (as the car is running), the starter gear is not dis-engaging.
Old 06-13-17, 12:25 PM
Jdub82
Jdub82's Avatar
Thanks alot guys but I think I may have lucked out. It seems there is a starter wire that runs behind the alternator right under the exhaust manifold and it has a connector that came unplugged. I reconnected and it started right up. Appreciate the insight
Old 06-14-17, 09:53 AM
aneidiaz
aneidiaz's Avatar
Great to know my friend! I'm happy for you! GodBless
Old 06-16-17, 08:51 AM
sha4000
sha4000's Avatar
How in the heck did it get disconnected?
Old 06-16-17, 09:00 AM
Jdub82
Jdub82's Avatar
I recently replaced the alternator, I'm assuming when doing so I may have pulled on it enough to get disconnected but remain in enough contact to start until now. That's th e best I could guess anyway.
Old 06-16-17, 09:05 AM
sha4000
sha4000's Avatar
Ok at least it's not a mystery and very plausible explanation.
Old 06-16-17, 09:58 AM
guzzy92fs
guzzy92fs's Avatar
Check that the connection doesn't have sulfate from the fact it wasnt properly connected, i would clean the terminals well with contact cleaner to avoid future problems.
levie
Performance & Maintenance
10-05-12 05:44 PM
m1k3yg
GS - 1st Gen (1993-1997)
15
10-06-11 09:23 AM
demon1
06-29-07 06:08 AM
nysupraman
12-05-05 06:38 PM
Quick Reply: 07 gs350 no start
