I have a problem with my rear camera in 2006 Lexus GS. Sometimes everything is okay like it should be, but usually I got this: http://imgur.com/X0FG4Gq
All the wiring for the trunk lid is in a ribbon cable (circled in figure 1). The easiest thing to do would be to take off the trunk lid liner and check that all the connections are tight, and maybe check the contacts for corrosion. Also, try the search function in this forum – someone has probably had this problem before so the solution is probably already posted in a previous thread.
