Most Used Torque Specs for Lexus GS
Hello Folks,
I often do maintenance work on my car and every time I take a bolt or nut off I am looking everywhere for the torque specs, I have piled a compilation of the most used ones, It will be interested if you guys can contribute to my list so whenever I need a torque spec I can come here!
This is what I got so far:2007 Lexus GS 350 RWD:
Oil Filter: 25 Nm (255 kgf-cm, 18 ft-lbf)
Oil drain plug: 40 Nm (408 kgf-cm, 30 ft-lbf)
Rear Differential drain plug: 49 Nm (500 kgf-cm, 36 ft-lbf)
Rear Differential Breather plug: 21 Nm (210 kgf-cm, 15 ft-lbf)
PCV Valve: 27 Nm (275 kgf-cm, 20 ft-lbf)
Wheel Lug Nuts: 103 Nm (76 ft-lbf)
Spark Plugs: 21 ft-lb for 14mm plugs (NGK)
Front Axle Hub Nut: 294 Nm (2998 kgf-cm, 217 ft-lbf)
Rear Axle Shaft Nut: 290 Nm (2957 kgf-cm, 214 ft-lbf)
Stabilizer bar link: 27 N·m (275 kgf·cm, 20ft·lbf)
The following 4 users liked this post by guzzy92fs:
Idorablo (11-09-23)
A couple more:
Front Differential Filler plug: 49 Nm (500 kgf-cm, 36 ft-lbf)
Engine Coolant Temperature Sensor: 20 N.m (204 kgf.cm, 15 ft.lbf)
Toe Control Arm Nut: 50 Nm (510 kgf-cm, 37 ft-lbf)
Shift Linkage Bolt: 16 N*m (163 kgf*cm, 12 ft*lbf)
Transmission Cross Brace bolts: 26 N*m (265 kgf*cm, 19 ft*lbf)
Rear Brake bleeder plug: 11 N*m (112 kgf*cm, 8 ft.*lbf)
Front Brake bleeder plug: 8.3 Nm (85 kgf-cm, 7 ft*lbf)
VVT Sensor Bank 1 and Bank 2: 10 Nm (102 kgf-cm, 7 ft-lbf)
Driver and Passenger Seat base front/rear bolts: 36.8 Nm (375 kgf-cm, 27 ft-lbf)
Battery Positive and Negative terminals: 5.6 Nm (57 kgf-cm, 4.1 ft-lbf)
Water pump bolts order:
https://cimg1.ibsrv.net/cimg/www.clu...x-01-34221.jpg
TOP left to right: A,B,C,A,B,B
Middle: B,A (on the right)
Bottom left to right: A,A,C,A,A,B,A,A
Water Pump Gasket bolts type A: 21 Nm (214 kgf-cm, 15 ft-lbf)
Water Pump Gasket Bolts Type B and C: 11 Nm (112 kgf-cm, 8 ft-lbf)
Water Pump pulley: 21 Nm (214 kgf-cm, 15 ft-lbf)
Idler Pulley #2: 43 N.m (438 kgf.cm, 32 ft.lbf)
Air/Fuel Ratio Sensors: Without Toyota SST Tool: 44 N.m (449 kgf.cm, 32 ft.lbf)
Air/Fuel Ratio Sensors: With SST: 40 N.m (408 kgf.cm, 30 ft.lbf)
Fuel Pressure sensor: 44 Nm (449 kgf-cm, 32 ft-lbf)
Camshaft Oil Control Valve: 10 Nm (102 kgf-cm, 7 ft-lbf)
Differential Carrier Bolts (8): 47 Nm (475 kgf-cm, 35 ft-lbf)
The following 2 users liked this post by guzzy92fs:
GS350ichiban (05-18-24),
skur (01-24-23)
This is what I found and some others:
Front Brake Caliper Bolts: 118 Nm (1,200 kgf-cm, 87 ft. lbs.)
Rear Brake Caliper Bolts: 54 Nm (550 kgf-cm, 40 ft. lbs.)
ABS Speed Sensor: 7.8 Nm (80 kgf-cm, 5.75 ft. lbs.)
Control Link to rear axle nut: 70 N*m (714 kgf*cm, 52 ft.*lbs)
Parking Brake Anchor Block Nuts: 76 N*m (775 kgf*cm, 56 ft.*lbf)
Rear Axle Shaft Nut: 290 N*m (2,957 kgf*cm, 214 ft.*lbf)
Axle hub and bearing to rear axle carrier: 70 N*m (714 kgf*cm, 52 ft.*lbf)
I'll look when I get home tonight and post the values. I have an F Sport sway bar kit waiting to be installed and I know the instructions list those torque values because those 4 bolts must be loosened to facilitate the installation of the front bar.
You mean nuts? To change swaybar just gotta remove the oil filter housing if i recall correctly. But maybe engine needs raising too I forgot. Btw when you raise the engine it makes the big tube pop off from the air filter box..
The torque specs are as follows:
Front subframe mounting nuts (1 per side) : 123 ft/lbs
Rear subframe mounting nuts (1 per side): 122 ft/lbs
Rear subframe mounting bracket nuts (2 per side): 37 ft/lbs
