Rotor Recommendation
Old 08-04-17, 11:50 AM
Hex357
Hex357's Avatar
Default Rotor Recommendation
Looking at getting new rotors. Buying and installing them myself. Ive already purchased Akebono Brake pads front and rear, now looking at rotors todo the job all at once. Ive seen alot of people go with Centric. So far thats my first choice, also considering drilled slotted rotors but not sure if they will make a differnece or are needed. Any suggestions?
2008 Gs350 RWD
Old 08-04-17, 07:04 PM
guzzy92fs
guzzy92fs's Avatar
I would recommend you sticking with OEM, i really dont trust any other for my gs:
https://www.lexuspartsnow.com/parts/lexus-disc-fr-rh~43512-22260.html
https://www.lexuspartsnow.com/parts/lexus-disc-fr-lh~43516-22010.html
https://www.lexuspartsnow.com/parts/lexus-disc-rr~42431-30290.html
Old 08-05-17, 03:50 PM
MX73
MX73's Avatar
Can't go wrong with Centric. Brembo blanks are pretty good as well. I had cross drilled on my previous car. Didn't care for them much. The drilled and slotted made a lot of "friction" noises but the braking was smooth and powerful. I would probably stick with slotted rotors if you want performance.
OEM rotors seem to use a "soft metal" and prone to warping. I've noticed it on my 2014 Mazda 6 and the GS.
I wish I could have brought some Centric rotors for my '16 IS200t. I was talking to the service guy at work and they said the OEM rotors on the F-Sport package tends to squeal when cold and it's a very loud squeal. There was a TSB out for a new part number but I heard that was a hit or miss deal.
Old 08-05-17, 09:14 PM
primavera
primavera's Avatar
Heard good things about Adam's Rotors
Old 08-05-17, 10:32 PM
masboy
masboy's Avatar
Stay away from r1concept eline rotors. Warped within a year or so....TWICE!
Old 08-07-17, 05:21 AM
L's TLS
L's TLS's Avatar
Yea I would avoid the R1 e-line. I went with their higher tiered rotors. Had them on other cars and had no issues, work great on my 07 RWD. Stoptech and EBC (have these on my Yukon Denali) are also reputable. I've heard good things about Adams.
R1Concepts (08-09-17)
Old 08-07-17, 06:34 AM
XJSFan
XJSFan's Avatar
Centric and EBC...
Old 08-07-17, 01:51 PM
Hex357
Hex357's Avatar
Thanks for the info guy greatly appreciated. Im going ot go with the centric rotors. Seems that is what works best for most people.
Old 08-07-17, 03:45 PM
guzzy92fs
guzzy92fs's Avatar
Now that I am checking those Centric Rotors specs, they seem quite good, not cheap btw, and now I remember I used them once for my Jeep Wrangler to improve braking when I lifted it, do you consider them to be better than the Stock from Lexus for the GS?
Old 08-07-17, 04:53 PM
pwrusr
pwrusr's Avatar
centric rotors. used them everytime.
rear 120.44141
front left 125.44138
front right 125.44137
they run about 60 each shipped via amazon
Brabusx2 (08-08-17)
Old 08-07-17, 10:01 PM
Lukas99GS
Lukas99GS's Avatar
I used centric rotors with akebono pads in the past on my 2GS and they worked great, just abs good as oem in my opinion.
Old 08-08-17, 10:09 AM
pwrusr
pwrusr's Avatar
Yup! OP I'm sure many people on the forum can second this
Old 08-08-17, 03:51 PM
Brabusx2
Brabusx2's Avatar
rear 120.44141
could you gimme model or link to the pad as well?
Old 08-08-17, 03:56 PM
MX73
MX73's Avatar
AKEBONO ACT1118 - 2008 Lexus GS350 front
AKEBONO ACT1113 - rear. If you are planning to do the rears, also pick up the hardware kit. You wouldn't want to reuse the old clips. I think it's about $15 both rear brakes.
It may be slightly cheaper on rockauto.com. You can find a discount code online that drops it down about 5-10%.
Old 08-08-17, 09:34 PM
CashLtd
CashLtd's Avatar
My car has StopTech pads and rotors installed by the previous owner. Cross drilled and slotted rotors with street performance pads. I've been pretty happy with them so far. Responsive and quiet. Brake dust sucks but it's great otherwise.
Quick Reply: Rotor Recommendation
