No start need help
No start need help
Ok so I tried starting my Gs 350 07 today n it cranked once then nothing. Since then it won't crank at all just turns the power on and shows the p/s light on along with the radiator fan on. I already charged the battery and checked the starter relay (the big one not the 30A) and forced the starter to work with paper clips but the engine would crank and not start fully. The gas is good. Battery is good. But now the battery dies really fast when I push to start to check the lights on the dashboard. The starters fine because I got it checked but don't kno why it won't try and crank without me forcing it to and even then it won't start.
just got a new battery and it's the same problem except when I first tried it almost started but wouldn't turn over after that nothing...Got all the fuses checked and they're good however the OBD has no communication and I previously had the check engine light in for the cat converter now it's not on only the p/s as well as vsc off and ((!)) light. Thermostat reads E as well. But all fuses are workin so I confused why it won't start but the radiator will turn on immediately no crank at all though
Have you checked for DTC's? Generally with smart start systems if it detects an error or doesn't register RPM during start procedure, it won't try again until the error has been rectified.
None will show up but I kno I had some on there like the catalytic converter but now it won't show or can even be read by scanners. Thinkin might be fuel pressure sensor or ecu because I read about it in some other post on here
When you pulled the battery the CAT error got erased.
Almost sounds like two issues. Like the cables from the battery are in bad shape and losing energy. If you force it to crank do any of the ground or +12v cables get warm? Look at all the connections between Batt neg, chassis, engine block and starter. Repeat for Batt pos.
WAG; any chance car thinks it was violated by paper clip jumper and is locking you out?
These cars have lot of redundant fuses. I'd suggest you check them all.
I wonder if it could possibly be a fuel pressure sensor, not a common problem on gs350's but ive seen several with it and the symptoms are that the car will crank over but not fire. I wonder if this has anything to do with triggering a fault for a catalytic convertor. But I suggest cleaning the terminals and just look around for anything loose. But before you go slapping parts on it and trying to figure out the problem. Take it to the dealer and pay for an hours worth of diagnostics, may save you more money in the end.
Too me it still sounds like you have a weak electrical. I would take apart the battery terminals, sand/inspect/clean all the leads. I would also do this with the engine ground, you may have a loose ground wire.
