2006 GS430 P0051 Oxygen Sensor Location! Please Help!
Hey everybody, my check engine light came on and the code that my OBD II is giving me is P0051. I would like to know the correct location of this Oxygen Sensor on the car and if its hard to get to. I think its Bank 2 sensor 1 (correct me if I'm wrong). From my understanding our 3UZFE engines have 4 oxygen sensors correct?
Is this the correct Part# 2344138?? (I just wanna make sure I get the correct one.)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/450x450/234_4138_sid_ra_p_fda9a41b091233e02556e4347f6207b15e8b0b80.jpg)
Found some more information (LS430 and GS430 same engine):
There are four O2 sensors in the LS430. They are as follows:
Bank 1 Sensor 1 - Driver's side (left front) on exhaust header. Lexus # 89465-50120 / Denso OEM # 234-4138 / Denso Universal # 234-4209 / Bosch OEM # 13441 / Bosch Universal # 15733
Bank 1 Sensor 2 - Driver's side (rear) near catalytic converter. Lexus # 89465-50140 / Denso OEM # 234-4167 / Denso Universal # 234-4209 / Bosch OEM # 15272 / Bosch Universal # 15733
Bank 2 Sensor 1 - Passenger side (right front) on exhaust header. Lexus # 89465-50130 / Denso OEM # 234-4630 / Denso Universal # 234-4209 / Bosch OEM # 13632 / Bosch Universal # 15733
Bank 2 Sensor 2 - Passenger side (rear) near catalytic converter. Lexus # 89465-50140 / Denso OEM # 234-4167 / Denso Universal # 234-4209 / Bosch OEM # 15272 / Bosch Universal # 15733
Looks like I need Passenger Side Bank 2 Sensor 1 Denso OEM # 234-4630. Dang, I answered my own questions and helped others at the same time.
![Wiggle](https://www.clublexus.com/forums/images/smilies/wiggle.gif)
Just wanted to keep you all updated. I installed Bank 2 Sensor 1 Denso OEM # 234-4630 and it fixed my problem. No check engine light!
I used the smaller size o2 sensor socket to unintsall the old sensor and install the new oxygen sensor. To test oxygen sensors with an ohm meter to see if they are good or bad watch this video here @1:07:
s2ne1 (05-22-22)
