2006 gs300 awd front right cv axle stuck in transmission
Old 11-05-17, 08:55 AM
ibidu1
ibidu1's Avatar
Snap a pic of how you have the bearing splitter mounted. Did you use bolts through it? The torque from the bolts should have easily pop the axle off
Old 11-05-17, 09:07 AM
ibidu1
ibidu1's Avatar
When you pulled the other side cv axle inside the transfer case shaft were you able to see the end of the cx axle that you couldnt loosen up? If its a straight through opening you can slide a long rod inside and hammer on the end off it.
Old 11-05-17, 11:22 AM
bdpride04
bdpride04's Avatar
update im able to get it out by following this
Watch "How to successfully remove a stuck inner CV joint." on YouTube
The following 2 users liked this post by bdpride04:
sha4000 (07-04-23), skur (03-03-24)
Old 11-05-17, 01:49 PM
lx4life
lx4life's Avatar
glad to hear!
Old 11-05-17, 02:57 PM
bdpride04
bdpride04's Avatar
Thank you so much for all your help. You guys are the best
wmj259
04-02-19 03:39 AM
bdpride04
10-26-17 08:57 AM
Jordan2006
02-24-16 10:57 PM
binhdeyho7
01-07-09 10:21 PM
Jongrok
01-14-06 09:01 AM
Quick Reply: 2006 gs300 awd front right cv axle stuck in transmission
