Steering Axis Inclination off spec.
5th Gear
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I just had my 2011 GS35 (25000 miles) alignment checked. Everything set ok except the Steering Axis Inclination (SAI) Specs are 8.6 to 10.1 degrees for left and right. The left was almost in spec (8.5) but the rich was WAY out of spec 29.9 deg. The car has never been in an accident of bad pot-hole bump.The dealer tells me SAI is not adjustable, it requires part changes, and if caster and toe in are ok it will not affect tire wear. It is hard to believe Lexus send cars out with suspension parts so out of spec limits; not by a bit, but a lot, essential should be 9 degrees and it is 30 degrees. Any thoughts on the implications and what to do.
Wow, that's strange to see an issue like that on a low-mileage car. Are you the original owner? If not, are you sure it hasn't been in an accident? I say that because the previous owners of my car tanked (what I believe to be) a curb, causing alignment issues. That, compounded with potholes and other city driving hazards, has led me to need a new driver-side axle.
For reference, the dealer quoted me $1,400 for a new axle (parts+labor included). Ouch.
Do you have any additional information?
5th Gear
I have had the car since new and it has never been bumped.
The dealer just said it should be ok if it does not "pull" and it does not so far as I can tell.
The alignment results sheet is attached.
If anything I would rather have a car thats been driven instead of parked most of its life. When you sit at idle rubber tends to sit at that location and dry up. That being said I would suspect your front lower control arm bushings maybe bad. Good thing its cheap and super easy to replace, if you can change a tire you can change these bushings.
You will need to take it to another alignment shop, preferably a shop that has a newer hunter laser alignment racks.
Here is the bushing I am referring to, it is the weak point in 3GS front suspensions as its a huge rubber bushing
https://www.ebay.com/itm/GENUINE-LEX...5aA1ry&vxp=mtr
