any major issues
Oil!
Keep an eye out, these engines tend to burn oil. Lexus allows for about 1L every 1000kms which is quite a lot. Also ask when the transmission fluid was replaced. If it's old your torque converter tends to have trouble locking up and starts shaking when going through gears.
can't comment on the AWD system but engine-wise, my '07 GS350 (my first lexus/toyota product) has been pretty good as expected from a Toyota. Bought mine with 90k miles from a private seller and immediately replaced the water pump (known issue with at least the early GS. I knew this was an issue with my car before I bought it.). It's a relatively easy job and I have a DIY video on it on youtube. My touch screen also stopped responding at some point, but that was a relatively easy fix as well (also on youtube).
Once that was out of the way, it has been just oil, oil filters, and other consumables. Did a few drain and fills of the transmission fluid early on while doing engine oil. 30k miles later I did the 120k mile service just recently with spark plugs, front brakes and fluid (more videos of that on youtube as well). All pretty easy to do thanks to the design and layout of the GS. It's a great car if you do the work yourself.
My channel is here: https://www.youtube.com/user/ez12a
Thanks for all the help, I am new to Toyota and I like the Lexus style on the GS, I did drive it for a short time and the Idol seemed a little rough ,
I was thinking a car trying to maintain a reputation like Lexus would run a little smoother,
Thinking after sitting it might just need a good tune up
Third generation
OK, well lets see
After less than a week owning the car I found a few issues,
The first is an exhaust leak between the cats and the resonators , it is one piece, can this be repaired as the used car dealer said?
The second issue is the break pedal going all the way to the floor ,
I had the breaks checked today, pads and rotors are fine
Anyone else have issues like this?
You inspected the rotors and pads but did you take a look at the condition of the fluid at the master cylinder? is it dark or a light color?
If it's dark, try flushing the brake system. You'll need at least the 32oz bottle of DOT 3.
As far as the exhaust leak, it can be fixed at an exhaust shop. Although a leak would indicate an issue with corrosion. Have you looked underneath to see?
OK, well lets see
As for the brakes, your pedal shouldnt reach the floor. You may have a bad master cylinder or water in the fluid.
Riverguy
RX - 1st Gen (1999-2003)
04-09-18 04:29 PM
