Transmission hard downshift from 2nd to 1st gear feels like getting rear ended
Hello all, a quick background about my vehicle, 2006 Lexus gs300 with 208,000 miles and transmission rebuilt at 170,000 due to being stuck in 3rd gear. Well all is well until recently my vehicle all of a sudden starts to have this hard / harsh downshift. This does not happen right before i put it into neutral before 20 mph coming to a stop. I have done searching and some member on ClubLexus have replaced their ecu through the dealer with success however, money is tight for me as of now. I have also heard of individuals replacing their selenoid/fluid with success. I am contemplating on sending my ecu in for rebuild by a company on ebay that repairs and ships back the repaired ecu/ecm. Any comments or opinions on your guy's experience in regards to this issue is greatly appreciated.
How did everyone whom experienced this issue resolved it and what was the cost ? Thanks in advance
Also i would like to remove the ecu/ ecm, can someone let me know where it is located? behind glovebox from what i understand, would i have to remove that as well to get to it.
You need a new Ecu unfortunately. Just save your money and have a certified Lexus shop in your area perform the work. It has to be programmed to your car so unless you have Lexus software access leave it to the professionals. My wife' car was doing the same , and with the new ecu drives fine again
I had the exact same issue on my 01' 430. See this thread_( https://www.clublexus.com/forums/ls-...g-to-stop.html )
My tranny fluid was dark and beginning to smell burnt. I checked the fluid and it was pretty low so I added about 1/3 qt and MY problem went away. But there are still problems in my tranny I believe
Hello guys. So I have already started pulling out the ecu. I’m not too sure if it’s the ecm locates in the engine bay or not. What controls the transmission? Ecu? Located at the passenger side under glove box?
So after some more research, i have concluded that the ECM (located under the hood) is the one that will have to be sent in for repair not the ECU (located at passenger side). I will update everyone on the end result for the members and others if they happen to come across this problem. I will overnight the ECM for repair tomorrow on monday and notify my results. The ECM will not need to be reprogrammed its PNP. The repair will consist of fixing bad capacitors and what not. I am almost certain that this is the issue, after countless research therefore, i will be going with this route. WISH ME LUCK EVERYONE! Here are some links that i found was helpful. A member, GEEYES300, had the same issue and he had sent his ECM in for repair with success.
HOW TO REMOVE ECM
https://www.clublexus.com/forums/is-...moval-diy.html
HELPFUL LINKS
https://www.cargurus.com/Cars/Discus...16018_ds771423
https://static.nhtsa.gov/odi/tsbs/20...61736-2273.pdf
https://www.clublexus.com/forums/gs-...0756-code.html
LINK FOR REPAIR
https://www.ebay.com/itm/Lexus-GS300...9ZJFbe&vxp=mtr
HOW TO REMOVE ECM
HELPFUL LINKS
LINK FOR REPAIR
I just had ecu fixed for $180..... SIA electronics. Don't go anywhere else. Save your money they're out of Illinois. It took about eight days of Having no car, but I only spent $180. Had it done last month.
thanks for the reply, may i ask why it cost 180? i saw an ad for 135. I used the same exact ebay link provide shown in the above post.
Hello all, just would like to update CL. My car is fixed! sent my ecm in to get repaired, and wow it is alot better than i had thought! I noticed my car drove smoother than before. There is no harsh downshift and my up shifts going from 3rd to 4th is a lot smoother compared to before. I do not know if there is a correlation due to the fix, however, i do notice a difference in performance. SIA have saved me thousands of dollars. I hope this post will help others if they happen to come across this issue.
JetCat (04-07-18)
Thanks a lot ToneTham!
I followed your advice.
SIA got my box on Wednesday and Shipped it back to me the next day on Thursday.
UPS says I will get it Wednesday January 31.
What a sweet solution.
Hopefully thats all.
Thanks again ToneTham!
I am having the same issue with my 07 GS350 (136k miles), but haven't check that yet with the dealer or any mechanics.
Should I check it first before I send to SIA ? Any recommendations?
hello, I’m not too sure, in my case I did my own research and sent my ecm in for repair. Money was short so I did not have any mech or dealership take a look. I know its not much help but I can tell you that my ecm was repaired and vehicle no longer has the issue. I would try not to drive the vehicle in case further damages may occur. Sia did tell me that this was a very common problem and they get a lot of these ecm repaired so if you have the money try that first. If you really have money take it in to get an opinion however in my case, I did not because I’m short on cash.
hey, glad ya did. I hope it will work out for you. Please update us on how the results.
sorry I have been really busy with school. I shipped on Monday, got there Friday, sat and Sunday was closed. They worked on it on Monday and shipped on Tuesday. Got the part back on Monday I believe so almost two weeks roughly. Please update us on your results.
