Transmission: GS300 vs IS250
Hello all,
I have a 2006 GS300 that needs a new transmission. I'm not looking forward to paying between 3 - 4 thousands on it because the car is not worth that much.
I have done some research and it seemed to me that the 2006 GS300 transmission is the same one in the IS250 (2007 and newer).
My question is: Does the IS250 transmission fits my GS300? Are they similar? because the IS250 transmission is much cheaper than the GS300.
What would you suggest?
Thanks!!
Thanks!!
Are you a rwd or awd? awd gs300 tranmsissions are a lot cheaper and can be had for around $500. rwd are pretty expensive and hard to come by.
The IS250 will not work! The only transmissions that will work are 2006 GS300 rwd and awd are different.
You can use this site to help you search junkyards in your area and or near you. This site also tells you which parts fit what, so for instance if the IS250 transmission were the same the system would list them for sale in your transmission search for a 2006.
www.car-parts.com
www.car-parts.com
Alnasri (03-24-18)
www.car-parts.com
www.car-parts.com
I have been looking at Carsparts.com, I found some options.
I would most likely buy one from there and have it installed in my car.
Thanks for your reply.
Have you taken your car to the dealer or a good transmission shop? You might just need to replace the fluids.
The fluid is old, burnt, and stinky as it was prescribed to me.
My is250 transmission needs replacement.
Hello all,
Thanks!!
Thanks!!
hello to all!
im from portugal and I’m struggling to figure out if the2013 LEXUS GS SERIES auto transmission fits on my is250 rwd. Anyone can help?
jehmin
11-10-22 09:12 AM
Kingdom934
04-08-18 03:05 AM
rockinalex
05-08-16 11:07 AM
LexusFan09
02-12-15 07:14 PM
