Tesla Style Headunit with OEM Camera
#76
Anyone know where else the Television Camera Controller might be located in a Japanese 2006 GS 450h? I looked behind the glovebox and that module is not present. There's just a space where the OP shows the location of theirs. I have NAV and ML system.
#77
Could you take a photo of what is behind the glove box.
#78
Sorry for the late reply. GS350H 2006 is similar to the GS300 2008 model in the wiring of the backup camera (post #12).
Follow the same steps for K47 plug behind the head unit.
You will need to power the camera with 6v output.
Can you send me a photo of the back of the original head unit please. I have an idea that might work.
#80
Hi,
#81
For the backup camera can I use the wireless transmitters from Amazon as a good alternative to the hard wiring hacks? Those diagrams and instructions looks like something from a NASA space shuttle
#82
Hi,
#84
My idea is to detach the part of the factory head unit which has the K47 plug and connect the plugs that are not reserved for the new unit to that part. I am thinking if it is possible to get 6v out of it.
If you see that hard to implement (i am not sure if it will work), then just use an IC as described in the link to convert 12v to 6v.
In case you missed the link, Here is a link discribing how to convert 12v to 6v :
http://www.toyotanation.com/forum/27...et-stereo.html
#85
If your car is 2006 then it is much easier than you think. It looks complicated, but believe me if you did it one step at a time you will be able to get it done. 😊
#86
Hi,
I did however test out the OEM cam with 5V and it fired right up. So, I’m going to run it like that for a while and see what happens. Under-voltage shouldn’t cause any permanent damage, as far as I know.
If it works out long term, getting 12V to 5V is as easy as any “cigarette lighter” USB adapter. I pulled a small one apart and just used the circuit board.
#87
I thought about that too, but it looks buried in the HU and I want to keep everything intact incase the next owner wants the original HU for some reason.
#88
I can this voltage conversion kit help with the install on the 2006 models? It’s supposed to the convert the 12v to 6volts for our rear view cameras. I took this snap shot from one of Dennis’s videos but he hasn’t replied with any details as of yet. I know the 2010-2011 GS models has a different method.
