My starter went bad huh? *Video included*
Old 05-10-18, 09:21 PM
Mesca
Mesca's Avatar
Default My starter went bad huh? *Video included*
Hey guys! Long time no talk..after 10 years of owning my 08 GS350, my first major issue. Guess it was going to happen eventually. All my lights are good, battery is not old by any means and just cleaned all the terminals. Now I'm left between alternator and starter. But I'm thinking with the way it is in this video I think it's my starter. Also the first time I tried turning it on the push start button would stay lit green, then turned into a pulsing green. Also a few times it tried turning on the only light that came on was the check engine light. What do you guys think?
Old 05-10-18, 09:54 PM
RXGS
RXGS's Avatar
When my starter went displayed the same issues
Old 05-10-18, 11:38 PM
ibidu1
ibidu1's Avatar
Most likely starter but first did you test the voltage to the battery and or tried to jump it? Also test the power going to the starter to make sure it is getting power before you tear it apart.
For starters you have options, you can jump on car-part.com search near you for your closest salvage yard. You can use starters off new low mileage 2017 2016 2015 GS or IS they all use the same starter and can be had used for cheap maybe less then 100 bucks. Better then using an aftermarket imo, you can also rebuild yours with new brushes for $55 bucks.
Old 05-11-18, 01:10 AM
Mesca
Mesca's Avatar
Yeah I tried to jump it and cleaned terminals but same result.
Old 05-11-18, 06:49 AM
Fausty
Fausty's Avatar
Just happened to my 460 a few months ago. Pretty much the same symptom was the starter.
Old 05-20-18, 10:47 PM
Mesca
Mesca's Avatar
Just resolved it, turns out it was a bad battery. Luckily the battery was still in the 2 year warranty! Ended up being a $5 replacement thankfully and not a $1000+ job for a starter or alternator!
coldone
05-23-19 03:52 PM
GSmamba
05-01-18 05:48 PM
aks92sc400
SC- 1st Gen (1992-2000)
12-07-13 05:44 PM
OneJay
Performance & Maintenance
21
08-15-11 03:24 PM
kenatl06gs
08-30-10 09:06 AM
Quick Reply: My starter went bad huh? *Video included*
