Moisture in headlight
Old 05-28-18, 08:09 AM
stellutz46
stellutz46's Avatar
Default Moisture in headlight
Seems like there are two conflicting opinions on headlight moisture, they’re not sealed well enough, or they’re sealed too tightly.
if anyone has had any success removing and correcting these things, your advice would be greatly appreciated.
thanks
Old 05-28-18, 11:06 AM
ibidu1
ibidu1's Avatar
Most likely a bad seal, or a crack have you ever removed the headlights or popped open any of the openings? If so go back and check the seals
As far as the moisture you will want to open the openings and either use a hair dryer or turn on the high beams on a hot day, it takes some time to fully dry the headlight as it may appear its dried once you hit it with the dryer but later you will find out the moisture gets drawn out from else where in the headlight.
Old 05-29-18, 12:36 PM
RXGS
RXGS's Avatar
Check the lense that goes about the low beam leveler. On both my old GS and my current one, this is where waster, or at least most of it, was getting jn
Old 05-30-18, 08:18 AM
stellutz46
stellutz46's Avatar
Thanks everyone for your help. Where's the low beam leveler btw?
Old 05-30-18, 09:45 AM
ShrinkDoc
ShrinkDoc's Avatar
In my old Volvos I had this problem, easy solution to dry. Opened up the back end by removing the "bulb" and allowed it to air dry. After 1 day of driving around with the opened back, the moisture would disappear. The problem now is how to seal tight, this will take some doing.
Old 05-31-18, 11:47 AM
pman6
pman6's Avatar
i don't think any headlight from any brand is completely air tight. It is intentional to let air in and out.
Moisture is always in the air, so if it were air tight with atmospheric air inside, under the right temperature, it would still have condensation.
You have no way to make a vacuum inside.
I would blow out all the water with a fan. Don't let the water droplets dry out on the lens, or they may leave water marks..
xtremex626
10-16-11 01:38 AM
mikegs2006
10-13-11 05:50 PM
sojah
10-07-09 06:23 AM
GS4_Fiend
07-18-09 11:35 AM
vindedreal
GS - 1st Gen (1993-1997)
08-30-08 10:05 AM
Quick Reply: Moisture in headlight
