DC Cut fuse on 2006
DC Cut fuse on 2006
I have been having a parasitic draw on my 2006 GS300. The battery will either be dead within 3 days or sometimes overnight. I put a multimeter in series on the negative terminal. I was measuring DC amps of 1.3A while car is off. I began pulling fuses and didn't see any change until I got to the DC Cut fuse on the passenger side fuse compartment in the engine compartment. After I pulled the fuse out the amps dropped to .1A. Does anyone know what the DC Cut fuse feeds? Does anyone have a schematic or wiring diagram? Any suggestions?
There is a fuse box diagram from the website, below --
http://www.autogenius.info/lexus-gs3...e-box-diagram/
The information in there seems accurate to me, but I am no means an expert. The D/C Cut appears to be Fuse 6 in the engine compartment, and is rated for 20 AMPS.
The tjing is that fuse controls the mpx-b which consists in a bunch of components. Try getting yourself locked in the car and listen to noises. Playvspexial attention to the steering column. Probably it's getting stuck and keeps on trying until it frains your battery. That's what occurs to me
H20wens (10-28-23)
