To lower or not?
Old 07-23-18, 04:11 PM
Leechmon
Leechmon's Avatar
Default To lower or not?
:sa
[i]Stock suspension,not sure if lowering just a bit will eff up
Old 07-23-18, 05:46 PM
Just4Me
Just4Me's Avatar
Looks nice both ways. you don't seem to have a lot of fender gap, so it's all your choice. Some ppl like the high look, none lowered, 20+ size wheels... some like the low look,,, lowered on 19s and under wheels... I happen to like the low.
Old 07-25-18, 06:18 AM
gr8fulRed
gr8fulRed's Avatar
i have enough trouble getting my low profile floor jack under the rear differential as it is.....at a stock height. How in the hell are people lifting their cars for maintenance after lowering them?? Lifts?? I DIY all maintenance so a lift is not an option for me. I like the looks...but don't need the extra headaches that it can potentially cause.
Old 07-25-18, 09:03 AM
XxGoKoUxX
XxGoKoUxX's Avatar
I use a low profile jack, and jack from the corners, not the rear diff.
I've never been taught (visually) where to jack from my rear diff, so I've never done it myself....
I just buy jackstands with the rubber adapters, jack up each corner, and sit the car on the jackstands.
FWIW, my car's about 1-2in lower on drive height (which is the height I use for everything).
Old 08-07-18, 09:22 PM
professorm
professorm's Avatar
Those are nice wheels. Your gap is not too bad. It actually looks decent. Lower always looks better, but it depends on if you want to deal with the additional headaches, firmer ride, camber, etc.
Old 08-08-18, 01:27 AM
designo
designo's Avatar
I never had a problem when I was lowered on OEM wheels and after-market 19's.
My 2 issues were basically the Tanabe Mid Pipes scraping on bumps and the front lip.
Here are a few pics:
Old 08-08-18, 01:04 PM
Leechmon
Leechmon's Avatar
I decided to just leave the suspension alone. Lowered would look great,but scraping the underside to hell just wouldn’t be worth it. I was low in my Supra,but my 350 looks good the way it is!
Old 08-08-18, 08:34 PM
professorm
professorm's Avatar
Those wheels have hardly any gap at all. What size wheels are they? What size tires do you run on them?
Your lip makes the front lower as well. What lip is that? your car is nice.
Old 08-08-18, 08:51 PM
Leechmon
Leechmon's Avatar
Hey thanks
they are Niche m149 Verona
20X9 and 20X10
Nitto Invo 245/35/20 and 275/30/20
the lip is a VTX VIP I found on eBay
I diddnt want to go full body kit,just something to accent
The following 2 users liked this post by Leechmon:
designo (08-08-18), professorm (08-08-18)
Old 08-10-18, 09:43 AM
garrryy
10th Gear
garrryy's Avatar
The 2x4 method .. Drive up on some 2x4s, depending on how lower you are, might need more than one to make a step higher then voila. you can fit the jack under the car. Used to always carry some in the trunk. Now living the 4x4 life and it is much less of a hassle LOL.
Old 09-19-18, 03:52 PM
alSpeed2k
alSpeed2k's Avatar
Our GS definitely looks like a 4x4.
On another note, do you have any more pictures of that lip? How's the fitment?
Old 09-22-18, 10:52 AM
HaryGahtoe
HaryGahtoe's Avatar
I’d love to see a picture of a lowered car that’s parallel parked with passenger doors opened.
Definitely not hating here because every car I’ve owned that wasn’t a 4wd was lowered as low as I could get it.
Love the feel. The look, yada, yada...
What ruined it for me was the first day I parallel parked the car, walked around to the passenger side and held the door open for my wife to get out. JC! I had maybe at most 1” till the door scraped the curb on flat level ground. It is stock height. As much as I’d love to lower it I just can’t damage the car doors just for stance. If it were on just a slight grade i’d have scraped the hell out of the door.
I’m enjoying the 460 even though it’s got gap is overall better than dragging my doors on the sidewalk, I still love the ride
All the brothers rollin’ on lowered rides; I salute you. Enjoy the ride. My heart is with you but my ADD self says it will cause me even more frustrations about trying find any parking spots I already have with a nice ride. My freinds and family already pitches a major fit about how long and where I end up parking them
Old 09-24-18, 01:40 PM
tcr101
tcr101's Avatar
drive up on wood blocks, then lift the car.
For the guys that go dumb low. get a spacer to lift your engine and tranny so you dont blow your oil pan when you hit a dip. I remade the front undershield with a piece of sheet metal as the plastic one was destroyed after hitting a pothole.
kamauxx
12-17-14 06:51 PM
mong
Suspension and Brakes
09-21-11 11:27 AM
maying856
03-24-09 03:02 AM
TLW
50
02-04-05 07:17 PM
elclassico
08-05-03 11:22 PM
Quick Reply: To lower or not?
