Correct way to rotate continental DWS 06 tires
Hey guys, I have approximately 20,000 miles on these tires. I rotated them at 10,000 miles and then just recently again at 20,000 miles. I didn't notice anything strange after the first rotation however after the second rotation there's definitely a difference in the way the car rides in the way the tires sound. They are much LOUDER.
Given that these are not directional tires, is there any specific way that the tire should be rotated, as in back to front or side to side? I had both rotations done at the dealership but I did not specify how the tires should be rotated. I assume that they would know.
i've had my tires rotated front to back/back to front AND fronts criss-crossed to the back and backs straight up to the fronts over the years (with various cars) and never noticed a difference in sound either way. First off, you should be rotating every 5k miles, not 10k. Secondly, depending on the tires tread life expectancy, when a tire is nearing it's last 10k miles of life or so....they usually become stiffer riding and cause more road noise. This is MY experience over the years. I bet more frequent rotations would help. It's possible you have a suspension component failing at one corner which is causing a slight effect on the actual tires tread (slight cupping, etc), and once it moves to a new location it's causing road noise and if its now on the front...it may make the steering feel a slight bit different. I've had that happen in the past with another car.
keejay7 (01-12-20)
Which DWS tires? some of the continentals are pretty loud after they're worn out, like gr8fulred has said.
You might not have noticed the noise because it might have been in the back (with less weighted load), but when you put more pressure on it, in the front, it might be a little noisier.
Also, depending on the model of your tires, you can have either DIRECTIONAL (will say rotation---> [with an arrow]), or ASSYMETRICAL (where your tires say OUTSIDE or INSIDE).
Make sure all tires are marked outside (if it is non directional), if your tire has that option.
Or make sure all tires are marked "ROTATION" with the arrow pointed towards the front of the car.
Most definitely, if a tire rotation is done wrong, it WILL make a lot more noise, a lot more noticable than before.
I have the DWS06, which are assymetrical. So assuming all fires were mounted correctly 20k miles ago, they are all facing out and it shouldn't matter which way they're rotated, right?
Maybe I didn't rotate them enough but all of my miles are highway miles so I don't think it matters that much. My last set of tires (Pilot Sport A/S Plus) lasted 65k miles and I think I rotated them twice throughout their life.
I’ll never buy continental DW again, it was so loud and it made a weird humming noise. That noise went away after I “flipped” my tires due to camber wear, then it came back again. Started to think it was something else other than the tires. But after i wore out the tires, switched to Michelin’s and then to hankooks and never had that weird noise again.
FWIW, for other members, I've had my Conti PureContact DWS for quite a while now (@ 90k, i'm on 130-135k rn, with 5k in between that i put miles on some 20s I had), so essentially 30k miles with absolutely no problems. Car has performed flawlessly, with little to no road noise (I can't even tell anymore since I drive with straight pipes now). I'm down to D,W, and about a few thousand miles of of S left, so I'm pretty sure I'm pretty far away from changing my tire.
My fiance's camry has worn a lot faster than I expected however. Her rears are worn down to the D indicator in the rear and D&W still exist in the front. I already purchased her a new set of tires though, the Conti true contacts. on HER vehicle... Even the rears make ZERO road noise. You wouldn't even know the tires were worn unless you stuck your hand back there and checked. Luckily I do a seasonal check every time I see discount tire have their tire sale (I think it was $300 for 4 continental tires). Then again, there are different factors, as she drives a VERY large sidewalled tire (215/60/16). She also neglects her tire rotations A LOT (which I yell at her a lot for, and i barely do myself... I've done a total of TWO tire rotations in the 30k miles i've driven.... and she's done maybe 3)
I can't complain about continental, as I've had nothing but good experiences with them. Even with my car driving lower than stock (bagged), The tire wear rate is phenomenal in my eyes.
Take a picture of the treadwear for us, you can also run your hands across the tread. If you have any chopping on the tire, meanings high and low spots that will create little pockets of air thus creating the noise tire.
Is this a rwd or awd? If its a rwd you can simply do a burnout and that will help level out the tires. Also if you mount the front to the rear and do the same. That can be your fix, if they are choppy!
GS2006
Wheels, Tires & Brakes Forum
42
04-02-09 06:42 PM
