Shaking in D/R+brake
i just got done replacing rings and seals on my 06 gs300 with 220k miles. No more black smoke out the exhaust, but when im in d or r, the car shakes back and forth. It needs all 4 struts(car rides on springs) and the vvti oil control valve connector is broken on one of the intake cams. Also it has regular gas in it right now, and the battery might be dead.
appreciate any input. I was quite happy the engine started and runs after i touched it with my crooked hands
Actually it was the fuel injector connector which came loose, i was able to push it back in with a stick without disassembling anything. Ill have to put some tape around the injector connector so they dont just slide off
put new 93 gas in it and this thing flies!!
te only bad thing us i got codes 0016 0017 0018 0019 so i probably messed up installing the chain somehow even though it seemed kinda stretched right away cuz one of the marks was just barely off.. it cant be off that much cuz like i said the car runs pretty great for a 220k mile car.
I literally had 30 error codes and was running on 5 cylinders thats why it had no power, wouldnt downshift, and would shake.
Somehow the shaking in D with brake pressed cured itself.
I just changed the oil to Pennzoil and put in 400ml of marvel mystery oil. And it just got real smooth at stoplights..
jdanielca
02-19-19 07:16 PM
