In replacement of brake pads ABS problem
The right side of the front brake caliper pistons were slightly stuck.
We were sensitized to work.
But, there was a small mistake.
One piston came out, got it back by twisting it and it works okay.
We put new Brake pads.
After that we noticed that the abs, vsc, ecb warning light is lit and the abs does not work and the brake feels a little soft. Both the car protrudes to the left and the left front tire locks.
What went wrong and what now?
I'm sorry, my English language skills is not probably very good
No, you will need to purchase techstream and a usb connector I think there like 15-$30 shipped.
After you have loaded the software, it will tell you to open the air purge fitting on the brake caliper and then the system will purge the air out. Also with the software you can see what your error codes are.
https://www.ebay.com/itm/New-Mini-VC...r=510669525262
LexNYC83 (03-26-19)
