Misfiring
Old 09-01-18 | 06:19 PM
cuongly267's Avatar
cuongly267
Default Misfiring
2008 GS350 with 129,600 miles
Just brought it.
P0300
P0301
P0303
P0305
Misfiring on the left side of engine. I already swap the coils with the opposite side and still getting those codes. Spark plugs seem fine.
Old 09-01-18 | 07:17 PM
ibidu1's Avatar
ibidu1
A while back I had the same thing happened to me, after I replaced the plugs. When I swapped the plugs on 2 or 3 plugs the rubber seal gasket inside the plug terminal was not seated properly and allowed water to get into the connection and foul the ignition. Take apart the plug for that one side and inspect the inside the terminal plug.
You also may have a broken wire on that harness, what you can possibly do is unplug each plug with a test light test the voltage on the plugs. If your not getting voltage I then would trace up the wire until you find the break.
Old 09-06-18 | 12:21 AM
mirfazil's Avatar
mirfazil
i work with gs 300 . when cold start car , misfire occur and rpm jump up , down. then p0300 fault code displayed
Old 02-27-19 | 07:55 AM
mark7is350's Avatar
mark7is350
Just brought it.
P0300
P0301
P0303
P0305
my friend had the exact codes on his 05 gs300 he replace ocv or known as vvt and the codes went away
Old 07-03-19 | 02:42 PM
loso167's Avatar
loso167
i replaced my spark plugs on my 06 gs300 awd. I immediately got a misfire code on cylinder 3 and 4. then I suddenly started getting misfire codes on all 6 cylinders. I think I just got ripped off when I ordered my spark plugs. so I just purchased some that were recommended from one of the threads. hopefully, this fixes this massive issue.
KTGS300
01-07-18 03:08 PM
eeric7
01-05-17 12:54 AM
bklynchris
11-19-11 11:14 PM
thaeleelyr
RX - 1st Gen (1999-2003)
12-22-10 06:44 PM
Redlexus07
04-13-08 12:12 PM
