Transmission problem (code P0751) shift solenoid A
I have Gs430 , 2007. Diagnosed check showed the issue with Shift solenoid A with transmission code P0751. However, I couldn’t determine which Solinoad A is from the 7 solinioad the car has. I would appreciate you help regarding this issue.
I believe "A" solenoid is first gear, "B" is second and so on. What kind of problems are you seeing with your transmission? How many miles do you have on the car and has the transmission ever been serviced?
Actually, I couldn’t determine which Slinoide was causing the problem, however I found that the transmission is cost almost the same as change the 2 slionide.I got all the transmission opened and checked it was really dirty from inside and then I decided to change all of it because I found that a secondhand transmission would cost me around $250 so I just changed all of it and the problem solved.
At the beginning I was keeping the option of changing the transmission as a last option however I went to four or five experts in this field and they said it’s better to change the whole transmission because you might get another solenoid broken it’s already drinen for around 200 miles.
GAGOO
RX - 1st Gen (1999-2003)
09-19-18 04:50 PM
Gmsd
08-09-17 05:50 PM
