Freshened up my parking brake
My parking brake was so useless and I was dreading doing this job but it turned out to be pretty easy.
Installed new shoes and all new hardware all for under $15.
I figured the cable was too loose as well because the parking brake was too loose when enabled, and yet was still scraping when disabled. So I just left both brake sho adjusters in their minimum position and tightened up the foot brake cable. Now when it's disabled the hub spins freely but when it's enabled it grabs super hard..
7-9 clicks should be the max it goes, that's how you know it's adjusted good and as the shoes wear away you adjust the thingies that make them go apart more.
Well I put a long breaker bar between the studs and tried to spin the wheel with it but it wouldn't bulge so I think it should hold 1200rpm. and didn't replace my ancient rotors, screw it. They're still good
Well I got it to hold it's own weight on a steep slope but it won't hold in D at idle..I think this is as good as it's gonna get without changing rotors and the cables...
I think I'll try that. Im gonna turn the adjuster to spread the shoes way out then go for a drive and it should wear away a little pad(shoe) material so it won't scrape with the ebrake off but hopefully I get to that "NY standard"
That would fail, The official state spec is "Must hold stationary at a slightly accelerated speed" Depending on where you take it, that can be interpreted.
There are quick lube places that only do inspections and no repairs. They will use the 1200 RPM strict test.
Many shops will put it in drive and see if it holds (if it can't handle that, it is a failure)
Some places, if they know you or are just lazy, won't inspect it.
Those drum parking brakes are also found on Crown Vics, Explorers, etc. They are a PITA to adjust right, Also, they have to be broken in, Use the brake to stop the car a few times.
It should drag a little when the parking brake is disengaged. Adjusting the cable is a supplement to adjusting the rear shoes.
