Tpms
Hello everyone I need bit help with my Lexus GS450H 2008
I changed my wheels from 18 to 19inch and I have to change my TMPS to the company I buying the staff set to me they can sell me and programmed new for me but when I fit the new one on my dashboard still showing the massage Check System do I have to reset something because I try to watch some videos but nothing.Thank you.
They set I have to reset but I try to looking for some videos but no luck I can’t found no information on my book.I think I have to call Lexus Dealer.
"Check System" message means that the IDs from sensors are not registered to the car's ECU. I was fighting with the same message after changing my winter tires (the summer tires were registered both to the "main" and "2nd" sets)... If you have Techstream, you can check what IDs are there in the ECU and check also more detailed DTCs, but you need some TPMS scanner to read the IDs from the sensors. Normal tire shops should have such scanners... and they should be able to register them too.
