2011 GS stiff steering wheel
Didn’t see a thread so asking what should I look for as the steering wheel is stiffer then before when I start the car and it’s stiff while I am driving it. Any suggestions to look into this problem. Thanks
That was the first thing I checked and it was at the correct PSI. Thanks for the reminder.
What kind of steering system does our GS have? It doesn’t seem to use steering fluids.
So if it’s electric like a arcade steering wheel then this could be very expensive or could it be there isn’t enough current going to the unit since it’s the original battery from 2011
Exactly because the system hardly ever goes bad, used parts for the steering are dirt cheap.
https://www.ebay.com/itm/2006-2011-L...7v3R:rk:6:pf:0
Chinorx3
02-06-19 08:34 PM
