2010 gs350 won’t start up HELP
Old 01-17-19 | 04:13 PM
Mariok12's Avatar
Mariok12
Default 2010 gs350 won’t start up HELP
So guys need some help I have a 2010 Lexus gs350 started the car up yesterday put to drive and as soon as started moving died on me . I try starting won’t start or crank at all nothing dead tried jump starting thinking battery dead nothing started is new so is batter checked all fuses are good checked every single one fast forward today after leaving car overnight went to try it and it start cranking as it was about to start it died the whole car has power radio lights etc all work smart key new battery etc no check engine light tried connection obd2 to poet says no connection anyone has any idea or know anything any input would be helpful
Old 01-17-19 | 06:29 PM
TopNotchIN's Avatar
TopNotchIN
I had a similar problem helping a friend with his 2011 GS350 AWD. The car was perfectly fine for months and then after sitting for a few days it wouldn't start. We tried jump starting the car and it wouldn't work. His cables were cheap, small gauge garbage. I used my 2 gauge cables and adjusted the connections on each vehicles battery until I got a good connection. After a couple of tries the car started up. I drove the car to the store and when I came back out the car was dead. Turns out the battery needed to be replaced. You stated that the battery in your car is new, but it may be defective. Take out the battery and have it tested. Also, is the battery to factory spec? Those "economy" batteries you see at the stores are junk. I believe the battery size is 24 or 24F depending on how the terminals are located. The factory spec is like 600 amps and 525 Cold Cranking Amps (CCA). You can buy a size 35 battery and put some cardboard underneath it to raise it up some. The size 35 battery is exactly the same dimensions as size 24, but is about a 1/4" less tall. I mention the different battery because size 35 batteries usually offer more power than size 24. It won't be a problem to change sizes either. My buddy's battery is size 35 with 700 CCA. Hope this helps.
Old 01-17-19 | 06:45 PM
Mariok12's Avatar
Mariok12
So problem solved it’s the fuel pressure sensor
Old 01-17-19 | 06:47 PM
gs350fan's Avatar
gs350fan
Yeah,you can wiggle the harness.
hammy954
05-03-23 04:58 PM
Nick3gs
12-18-20 11:20 AM
wallywall8
06-26-19 09:04 PM
Jlogo1985
03-25-18 04:06 PM
Mrridinlow
12-17-16 05:05 AM
