Tpms disable gs300 -06 ???
Hey, after about a month of googling and testing I give up and I have to ask.
Anyone know how to disable the TPMS system completely?
Not looking for any "tape the light" solutions or "its illegal" answers.
I cant stand the "check system" light anymore.
Oh and its legal here in Sweden. Please somebody HELP!
Unfortunately there is no option to disable this feature, it has to be built to comply with so many regulations that while your country may not require it, others do so they cannot build a disable function.
I dont see why you would go through the effort/time to disable it, it is a safety for you. Use that same effort to repair it if its broken. Personally It has warned me plenty of times of when I get leaks in my tires, due to nails, or just low psi. One time I was speeding on the highway without realizing that I had an almost sudden blow out, but before the blow out the warning system got triggered and I quickly pulled off the road before allowing it to go fully flat.
The system is simple, if you have aftermarket wheels just swap the sensors to the new wheels. If the sensors are old and have dead batteries, buy a set of denso sensors off ebay there like $120 bucks for a brand new set, buy a teachstream $25 and register them yourself, or take it to the dealer or car tire location many have tpms computers.
A similar thread came up in the 2IS section as well and again not all models are equipped with TPMS, depending on destination. (Korean-spec 2IS models don't have TPMS).
Do you have any idea what methods were attempted?
Jeff
The interesting thing about that, is that not all countries have TPMS on the GS. For example, some models made for Chile do not have TPMS.
Jeff
Jeff
Jeff
Jeff
There was a post a couple of days ago that was talking about splicing two wires going to the TPMS module to disable the light on the dash. Might be an option, but I have no idea what other effects this might have, or if there is a definitive wire color for the GS, as it seems the wire colors vary by model.
For sure, Toyota/Lexus has many reasons for deciding what options/features will be included on certain models. TPMS is not required in Canada for example, but Lexus models in Canada generally have TPMS. That said for Toyota models, Toyota initially included TPMS on Canadian models only to start removing it on models a few years later.
There are a lot of factors for these decisions,
It's definitely possible to disable TPMS in the 3GS, the question becomes is it worth the money and effort to do it. I'd rather just run the system myself.
Jeff
Jeff
I think the latest defeat of the TPMS is to due the PVC Pipe trick. Grab your TPMS throw it into a PVC pipe with a fill nipple and set the PSI. It's super sketch but it wont throw the warning.
I'm getting tired of my tpms and i'm in canada and it's not required :/
Trick works if you have a working set of TPMS sensors. I was going to recommend this but if you need to replace a sensor, you might as well put them back in the wheel (unless you have aftermarket rims that doesn't play too nicely with TPMS.)
