LED High Beam
After changing the DRL’s to the accessory style city lights only, I now can look forward to a true LED high beam.
My question to those out there is; what kind of success or failures have others tried?
Thanks for replies
Thanks for replies
How did you switch the DRL to the city light? I have a LED high beam kit from DDM tuning. They are extremely bright when the highs are active but strobe in DRL mode. This kit doesn't handle low volts nicely.
After hours of going thru the relay and fuse panels for 3GS; reading and researching I can’t find a corresponding relay for DRL’s alone. Found highs and low but nothing to match the 5 to 4 post aforementioned in the rx threads that can keep high beams but drop DRL’s
