Fuel pressure torque specs?
Old 03-06-19 | 10:50 AM
sonyxbr80's Avatar
sonyxbr80
Default Fuel pressure torque specs?
Does anyone know the torque for a fuel pressure sensor of a 2008 GS350?
Old 03-08-19 | 01:20 AM
potatomon's Avatar
potatomon
24 NM if using sst 09922-10010
31 NM if not using
From Lexus tech doc
Old 03-08-19 | 05:45 AM
sonyxbr80's Avatar
sonyxbr80
Default Thanks, this is what my friend told me also using alldata tool
31 NM if not using
From Lexus tech doc
So roughly 23 ft lb, many thanks
Old 03-08-19 | 06:38 AM
ibidu1's Avatar
ibidu1
For stuff like this I like to hold the wrench near the base (so you dont put a lot of leverage) and once its tight make a click sound. I dont like using torque on specific stuff like this, the only thing I use torque wrench is if I tighten crucial stuff like heads bolts/camshaft/crank/rods etc. Sometimes you can over torque stuff by accident, and snap bolts.
Old 03-09-19 | 07:49 PM
potatomon's Avatar
potatomon
The hollow ones give a fake impression of being strong too. I broke the vvti bolt like that and like 2 headbolts cuz I was using the angle gauge but the bolt was binding and the tool only works when bolt is moving smoothly but once it breaks it's not stuck in there anymore just drill a little hole, hammer an Allen key and get the bolt out but I did give myself a big scare
For this specific bolt I used a set of adjustable pliers did the job fine
sparkyguy
Performance & Maintenance
05-01-17 07:38 PM
bb430
03-17-15 03:02 PM
SC300_704
07-10-10 06:32 PM
shajbot
04-28-09 10:22 PM
spooksh13
08-11-06 09:01 AM
Quick Reply: Fuel pressure torque specs?
