Gs300 tm fluid change
Old 05-01-19, 11:38 AM
Easy2take
Easy2take's Avatar
Yeah I did notice success with amsoil, but it is not available in my region.
Have you heard anything about any other brands, like motul, molly, kroon oil, bardahl or anything else?
The following 2 users liked this post by Easy2take:
enshiu (05-01-19), User 122922 (07-13-21)
Old 05-01-19, 11:59 AM
tghw
tghw's Avatar
Originally Posted by Easy2take
Wait, did I see it correctly and you used Mannol ATF?
I'm asking because all I hear all the time from almost anyone is that you should use only Toyota genuine ATF WS, nothing else will be compatible with this factory fluid and may ruin your transmission once mixed. Always been wondering if that's truth.
So did you have any problems after mixing it? I did replace 3qt of my fluid with Toyota WS together with a filter, but I want to flush out old fluid completely out with other brand's compatible ATF, since as far as I know Toyota WS is not fully synthetic fluid.
How is your car driving so far?
enshiu posted a picture of Toyota WS fluid directly above your post that clearly shows that Toyota WS fluid IS synthetic. Do you not believe your own eyes?
enshiu (05-01-19)
Old 05-01-19, 12:49 PM
Easy2take
Easy2take's Avatar
Picture he posted has a Mannol branded fluid as I recognize, not a toyota branded ATF WS fluid.
Old 05-01-19, 06:02 PM
potatomon
potatomon's Avatar
They don't make the transmission or the fluid for it. It's just rebranded atf. You can use any ws fluid
enshiu (05-01-19)
Old 05-01-19, 06:23 PM
enshiu
enshiu's Avatar
I replaced five times 2qts and fifth time filter plus 2qts. Total replaced 10.5 qts (9.9litres)
According to my FSM I only have 8qts in my gearbox so this should be a fully dilute way to clean all the old fluid out.
1st time: 2quarts
2nd time: drive around the block and 2qts
3rd time: '' 2 qts
4th time: '' 2qts
5th time: filter and gasket plus 2.5 quarts
According to German laws they can not put fully-synthetic on the packaging if it isn't fully-synthetic
According to TUV:
Mineral
Semi-synthetic (Any mix more than 50% mineral)
Synthetic (Any mix less than 50% mineral)
HC-Synthese (Hydrocarbon recracked oil made almost near fully synthetic 90%>)
Fully-Synthetic (99%>)
Toyota also buys their fluid from third parties. My bottle oem ATF WS says ''made in Germany'' Mannoel/Fuchs and the MT 75W LV says ''made in France'' > Motul.
So far so good clocked now over 700mls (1100km) and still smooth as silk.
Old 06-17-19, 04:55 AM
FLYIN4D
FLYIN4D's Avatar
Hello. I'm in the United States. So I'm about to change the fluids in our car. I believe they have changed the TM fluid before at the Lexus dealer. I guess I'll have a good indication when the fluid comes out. Either way, I'm going to still change it, and the filter. So, do I need to go to the Toyota dealer and get the Toyota ATF-WS Synthetic transmission fluid? I'll make sure I buy enough and use the method folks are using here. Please advise. Thanks.
enshiu (07-31-20)
Old 06-17-19, 09:59 AM
enshiu
enshiu's Avatar
To flush the full system out get 10qts.
Old 07-13-21, 07:40 PM
User 122922
User 122922's Avatar
Originally Posted by ibidu1
Many guys have been mixing amsoil with great success
Do you recommend me using amsoil at 110mi for my 1st drain n fill or the transmission might act up ? My transmission never had any maintenance before!! So I’m wondering if I can mixing it up since ws is not synthetic and amsoil 100% full synthetic and from what I heard it’s really effective and high quality
Old 07-13-21, 07:46 PM
User 122922
Originally Posted by enshiu
So I changed 8qts by driving around the block and diluting the old fluid out:
I changed total 6qts and the last 2 qts I dropped pan and filter. I changed total 8 qts.
Car shifts much more smoother than the old jerky way. I can't even feel change in gears.
is this was your first drain n fill at 185mi ? Because You kinda gave me hope on my 110mi 😣😫
bkos90
03-03-15 02:03 AM
redjeeper
Maintenance
18
10-04-14 07:47 PM
DMPesso
Performance
16
12-10-10 11:55 AM
advsystems
Maintenance
08-31-04 03:14 PM
Quick Reply: Gs300 tm fluid change
