Having track control, abs , brake , vsc , and red triangle lights on dash
Old 07-03-19 | 08:23 PM
silverlake's Avatar
silverlake
Mine did that too it was the bank 2 code said my cat converter was below threshold I bought cat cleaner and after 200 miles the light went off and hasn’t came back in months
Old 07-03-19 | 08:25 PM
Antc2's Avatar
Antc2
Originally Posted by silverlake
Have you had a code reader print the troubleshooting codes ?
My check engine light doesn’t have to be on? To read the codes.. Ik I might sound dumb rn
Old 07-03-19 | 08:31 PM
silverlake's Avatar
silverlake
Might still have a code stored can’t hurt to try it I’ve heard faulty seal on gas cap could do it I’ve also had it happen with cheap gas
Old 07-03-19 | 11:14 PM
Antc2's Avatar
Antc2
Alright ima have to check it out thanks for the info
Old 07-04-19 | 02:55 AM
ibidu1's Avatar
ibidu1
Originally Posted by Antc2
So I checked my alternator and my battery the voltage is good but the measurements weren’t good, but starter and alternator is good. Is it the battery for the lights?
What were the voltages? These cars when the voltage is low it triggers a bunch of lights. Grab a volt meter and put it on the 20 volts and measure the voltage, with the car off, then measure with the car running, and then measure at 4k rpm's.
Old 07-06-19 | 12:33 PM
Antc2's Avatar
Antc2
The battery is good just checked it. What else could be the problem
Old 07-06-19 | 01:39 PM
ibidu1's Avatar
ibidu1
What are the voltages numbers? Im only guessing is that the alternator is going bad
Do this test, and see what numbers you get.
Old 07-06-19 | 05:56 PM
Antc2's Avatar
Antc2
https://www.youtube.com/watch?v=LGB6ZEjGm7Q&t=235s
Ima check it out and I checked it w the scanner and no codes at all, and I reset it still no codes
Old 07-06-19 | 08:21 PM
Antc2's Avatar
Antc2
When advanced checked my battery they said it was good and they checked my alternator they said it was good
Old 07-07-19 | 03:02 AM
ibidu1's Avatar
ibidu1
it sounds like you will need a scanner and see if there are any codes. See if autozone can scan it for you aswell
Old 07-07-19 | 10:35 AM
Antc2's Avatar
Antc2
I tried that yesterday my uncle had one and he tried resetting it and nothing happened
Old 07-07-19 | 11:49 AM
mkeeney's Avatar
mkeeney
This error does not throw an OBDII code that can be read with a typical scanner. You need Techstream or a higher level scanner.
Speedymonk
CT 200h Model (2011-2017)
07-02-19 08:20 AM
zippinbye
GX - 1st Gen (2003-2009)
12-03-17 02:35 PM
dmartine62
Maintenance
11-15-13 09:40 AM
texusboi23
12-25-12 12:45 PM
dscokin
10-14-08 10:40 PM
