Clunking rear left tire area ANY MASTER TECHS?
i reread your first post and I definitely remember the similar situation as you explained which was solved by replacing both wheel hub bearing assemblies with new reputable parts (koyo or timken).
Have you also tried to spray wd-40 in the strut bushing area and upper mounts to isolate the sound?
Really hope you find this stubborn noise.
hey there, cant recreate the sound unless its under a load... and already moving at 5mph. the popping is only from the right side. and yes i used timken hub. and brake shield is definitely far away from the rotor. that noise is way different from what im hearing. i really dont know what to think anymore. but its definitely goin to lexus tomorrow as i picked my son up today and want to spend time with him, instead of taking the car apart and not spending time with him lol
Again, good luck tomorrow!
Hey everyone!!!! It's been diagnosed and fixed..... You will never believe what it is.. This literally drove me crazy!!!! So.......Drum roll ladies and gents......... It was the suspension... Not any of the parts that went bad or wrong or even yoy would think of..... Get this, they found the absorber actuator, the sensor inside our trunk, on top of the strut that twists on. The two metal clips that hold the sensor on to the strut top had broken/fallen off.... They wanted to charge me $817.64....... Don't do this!!!! Thankfully my buddy who was a tech up there, I asked for him to diag it. He came to me outside and told me an easy fix..... These metal peices that go on this, just tear your trunk apart to find the metal clips, bend them back and superglue if need to be so they wont slip off. PROBLEM FIXED!!!!!!! Arggggggggggggggg I'm so glad this was an easy fix!!!! Fix I wasted alot of time and parts here and there..... But this was definitely overlooked. Please check these actuators before anything!!!!!!!! Hope this helps many!!!
Kingtut89 (08-13-19)
