P0420 and P0430
P0420 and P0430 codes - Lexus techs?
2006 GS300 AWD. Was getting a exhaust rumble coming from under the car so took into shop and they said mid-pipe needed to be replaced (cats were going out). There were no engine codes before replacing the mid-pipe. Bought a new mid-pipe and (2) new denso oem downstream o2 sensors. Shop installed the new mid-pipe but said they couldn't do the o2 sensors. Next day check engine came on with p0420 and p0430. Thought it might be the o2 sensors so I installed the new o2 sensors and cleared the DTC. Came back with the same issue. Here is the techstream data. I'm not sure what is going on. My thought is there is an exhaust leak in one of the seals/gaskets of the mid-pipe but I don't know what the values/fails mean. Can anyone help? Thank you.
A whole new Y-pipe or mid-pipe bolt on with (2) new cats.
https://mufflerexpress.com/collectio...verter-3-0l-v6
2-year Option.
2-year Option.
Here is more detail on each FAIL with a description from techstream. I'm hoping a Toyota or Lexus tech. can pinpoint what the issue is.
Catalyst Efficiency
O2LENB1B = RrO2 sensor locus length of Bank1 catalyst for "B" area
O2LENB2B = RrO2 sensor locus length of Bank2 catalyst for "B" area
O2 Sensor
.45V MOR B1S2=Maximum time while sensor voltage exceeded .45V continuously for Bank1 Sensor2
.45V MOR B2S2=Maximum time while sensor voltage exceeded .45V continuously for Bank2 Sensor2
F/B Comp B1S2=Percentage of time when sub-feedback compensation factor remained greater than or equal to .05V for Bank1 Sensor2
F/B Comp B2S2=Percentage of time when sub-feedback compensation factor remained greater than or equal to .05V for Bank2 Sensor2
Area 4 B1S2=Percentage of the time when sensor voltage was .7V or greater for Bank1 Sensor2
Area 4 B2S2=Percentage of the time when sensor voltage was .7V or greater for Bank2 Sensor2
Catalyst Efficiency
O2 Sensor
3rd Gen GS300 AWD P0420 code after new everything
currently having the same issue and I got new sensors, headers, mid pip and Tanabe Medallion Axle back.
I was told the O2 may need a spacer but I'm not sure how that would do anything. I am aware of the carbon issue so we'll see how this plays out.
swaangin
09-11-19 07:02 PM
zippinbye
GX - 1st Gen (2003-2009)
10-21-12 06:00 PM
LexFather
02-18-12 05:49 PM
Rex Ruthor
06-15-08 10:49 AM
