TPMS light ONLY when traveling (not local driving)
Should I replace my TPMS sensors with my upcoming tire change on 08 GS350 w134k miles?
My TPMS light ONLY comes on when I am driving on a long distance trip of more than 40+mins. Sometimes it comes on at 45mins into the trip, sometimes it’s 2hrs, 3hrs etc.
it does not come on for local driving, although I do similar driving times locally. My work location is typically 25 mins drive, mostly highway, sometimes I work in other locations about 45 mins away. The light does not come on locally. It only comes on when I am on these trips. I take 7hr trips about every 2-4 weeks.
The symptoms makes me think that the batteries are going dead. My tire pressure is always fine.
Do you think it is normal for the batteries to die around this age?
I am not sure how to interpret the results from the scan tool for TPMS. My light was not on while it was being scanned.
Should I just go ahead and buy new sensors?
Weird that your are able to get a tire psi, this tells me the sensors are all working properly. Would be nice if you could use the scanner and scan the sensors when it acts up.
10+ years is a lot for batteries, if you do install new ones. I would use a good quality sensors like denso, and avoid cheapy china sensors.
Or would it be a good idea just to go ahead and change them?
If youre going to replace the tires I would replace them, rockauto.com has denso for $32 each
Thanks, I called Discount Tire and they say that they would program them included in their cost of tire installation, which is already cheaper than other tire places.
Discount Tire (09-04-19)
