The Tesla Display Video install -with AMP and DSP
#438
the videos i post are for factory backup cameras instead of after markets ,i do have wiring diagrams for the ls , so stay tuned into my vidoes ill be posting ,id the gs ,next is is250 then ls models
#439
My wifes camry has Android 11 instead of 10 like we have?
They are making a new unit for ours that runs what android 11 instead of 10. It's in the early stages. I have had both of my cars (08 LS460L executive package / 2010 LS base) at Phoenix Automotive to get the signals down so the new units will work and not be so buggy like the current ones. The reason why the current ones are so buggy when they developed it, they only had only one version of our car and tried to make it work for all of them.
They are physically making new units and will make new software for units....
#443
After working with the techs from Pheonix have a couple Questions cant get signal still from back up camera...
2008 LS460L with park assist
1. This is the diagram that they sent me and I connected wires.
but then someone on clublexus posted this diagram
Does this mean my camera positive (red wire inside stripped RCA ) is 10 and fraid cable in rca should be on 34?
Does this leave pin 35 with getting the Step down 6 volt signal from convertor?
Do I have to attach anything to 35?
Thanks in advance for you help.
#444
ill take a look at the diagrams i have a make it more easy to understand
but for what i see there TRY THIS
1= CB+ RED and WHITE wire twisted together for the volt 39
2=C-GND Wire to ground some where
3=CV Ground on striped rca plug
4=CV+ RED WIRE ON RCA PLUG
TRY THAT
TRY THAT
#445
Thanks
#446
put a multimeter to pin 10 and then put it in reverse and see if you get voltage .then we go from there
they have given you the wrong diagram
