The Tesla Display Video install -with AMP and DSP
This is my attempt to make an install video of my android Tesla screen.
there are alot of bad units from CHINA CIRCULATING ,you get what you pay for ,so to not get one with wiring problems get it here in the link below
https://www.dentechmods.com/
There are 3 versions and I'll show you each one you have
1= The T3 (one with ****)
2=The px3
3=The px6
I have all 3 right now I'm on the px6 ,new video coming soon
heres there product ,in the USA
ill go over
in post 2 below you will see fixes
1-airbag fix
2-hazard button fix
3-air conditioning fix
4-steering wheel control fix
5-OEM camera wireing ,added to post 2
now ive been lucky i worked with Dentechmods.com android to send the correct harness via vin number
most of you take pictures and hope you get the right harness from ebay and overseas vendors.
If you have a bad unit i now how to fix most issues
6 PX6 Firmware update link ;
send email to this link to sergey and request a firmware update in link below
Sergey Kozlov
shivadest@mail.ru THIS IS THE EMAIL FOR NEW FIRMWARE ,MENTION (dennis) and he will take care of you
just message Sergey Kozlov and give info of your unit he will email you instructions it will look like this
Changes:
1. WiFi icon click is open WiFi settings
2. Added Online Update button to Apps — System apps list. Click to check Online Updates
3. Fixed 4-Zone button text for Climate window for Land Cruiser 200
4. AppVer is 20200324
5. Something else
You have to copy px6-1920x1080.zip to the root USB Flash (must be formatted as FAT32 file system).
After it You will get px6-1920x1080.zip (file must be named right that) at the root of USB Flash.
Unplug ALL USB sticks/drives and etc from unit,
0. Open App List, press Tesla PX6 Updater. Then select 1920x1080 (big or small display, use the one You used before) radio button and press Install. Wait until it closes.
1. Attach USB, You will see Information about Install Firmware Update.
2. Head Unit will be rebooting and firmware will be installing.
3. When all is done, You will see prompt about remove USB. Remove USB and HU goes to restart. Unplug USB while boot logo. to prevent repeat of install
then take a picture of your system, and then send it to him
Best regards,
Sergey Kozlov
shivadest@mail.ru
Dsp here
https://www.aliexpress.com/item/4001...1-cbde309ad90e
ill be installing the PX6 next to test it
WHEN ordering the PX6 MAKE SURE YOU SEND THIS PICK IF YOU HAVE A 2010-2011 AND VIN NUMBER SO THEY GIVE YOU THE CORRECT HARNESS ,IN THE PIC IT HAS ALL THE PLUGS YOU NEED
Here we have the px6 FIRST BOOT UP FIRMWARE UPDATE
factory back up camera introduction part-1
part 2 will be setting the old grungy looking camera to better contrast and brightness
part 3 will be wiring diagram ,very easy if you follow my easy steps, you dont need to run any wires to trunk
Google assistance working well (Ok Google)
air conditioner new display
Android Auto, Apple Carplay
Free maps ,no internet needed
Custom Logo
bacup camera parts list
part-2 monitors
Hazzard button fix
backup camera part 3
backup camera part 4 (for 2006 models)
Airbag Fix
2007-2009 backup camera
Q&A Video
Firmware update
so i called PHOENIX ANDROID they says they have a unit for the 2010-2011 with a fibre optic DSP AMP 12 channel 50 watts RMS OUTPUT
so i bought it,this one below ,not as fancy as the one above but better than my factory one
the one below was pricey ,but this was the only company which has a unit for 2006-2011 so i bit the bullet
and now im a happy camper
so i read on the blogs that members were having problems with the backup camera ,air bag light ,hazzard button not working
so i asked phoinex does these units have these problems, they said you would be the first with the 2010 unit and if you have any issues we will resolve it.
so i said lets take another chance on one of these units.
i plugged it in and it worked , but it had the airbag light on hazard button didn't work.
i called them and they said send me your old unit and we will probe the connections
so what they did was test all the components because the harness they sent was for chinese market
a week later they sent me a new harness all my problems solved
The best thing is the DSP amp..ill be doing a video on the amp
heres a link what it like ,exact same unit but phoenix android called it carda
this is the old amp
this is the new plug and play
you can use your laptop to tune each speaker or use the tesla screen
HERES THE THE TIRE PRESSURE GAUGE
then updated tweeters from this
to this
cables to run to the radio
now for the display
THIS IS THE UNIT
any question let me no,
this unit works beautifully
heres the order on phoenix androids site
2=The px3
3=The px6
ill go over
1-airbag fix
2-hazard button fix
Sergey Kozlov
Facebook Post
Changes:
5. Something else
Best regards,
Sergey Kozlov
shivadest@mail.ru
Dsp here
Custom Logo
part-2 monitors
Hazzard button fix
Airbag Fix
Q&A Video
Firmware update
this is the old amp
to this
now for the display
THIS IS THE UNIT
The following 3 users liked this post by verly6565:
backup camera diagram for the 2006
At the back of your tesla sceen there should be a brown wire that says back connect that to pin 13 on the k46 plug
then remove glove box and find the k64 plug .and follow diagram
2007-2009 backup camera wiring
2010-2011
these to plug are behind the deck watch the video
The Security light fix =problem doesn't activate when you lock the doors
first remove lower plug from the Tesla unit
then locate the purple wire in tplug (theres 2) the one with the arrow pointed to it
then attach a wire to it and connect into **** 6 in the k99 plug green wire
now your done
This is the air conditiong fix
this how you add the brackets just drill to holes ,by using the template provided with the unit
This is the AIRBASG fix ,ask phoenix android for the 3 wire chip
you will get this
back in 2014 this was my first set up
2010-2011
now your done
you will get this
bebe85 (10-11-19)
This is my attempt to make an install video of my Phoenix android Tesla screen.
https://www.youtube.com/watch?v=pGf2uz55lNA&t=11s
First i purchased one from alibaba for $500 went to install it and found out the plugs were differnt this is it
did not work for 2010-2011
so i called PHOENIX ANDROID they says they have a unit for the 2010-2011 with a fibre optic DSP AMP 12 channel 50 RMS OUTPUT
https://www.youtube.com/watch?v=yR5OsrDj8vA
https://www.youtube.com/watch?v=FZCbbZ77lmo&t=16s
this is the old amp
now for the display
this is the unit
this is the old amp
now for the display
this is the unit
PauloFR (06-21-20)
I got it from Phoenix Android
i did not have to replace the factory amp ,but on the web site it had an option for a DSP AMP,so i bought it with the screen
let me tell you the low bass makes you think you have a box in the trunk
What the amp has is a built in dsp sound processor so you can tune every speaker individually its incredible ,
when your tunning it comes on the screen ,you can use the presets or use youer own and save it and give it a file name
mind you all you do is go to your trunk yank out your factory amy and plug this in with the same cnnectors
you can also screen mirror easily and use the the tesla screen touchscreen
ive tried android auto and apple carplay and there a little laggy
the one in the unit mirrors your phone exactly
my next video will be me showing you how the functions work
bebe85 (10-12-19)
A lot of the Tesla unit's were thrown on the market without testing for the us market, so I sent my unit so they could get it right.they worked with me to get a good product out to the us market. Off course not everything is perfect with aftermarket radios
But mine is working fabulous, I don't have to upgrade speaker's, I just tune them.but I did upgrade my tweeters
i worked with them to resolve alot of issues now they are great machines in your car
this is the order
this is the order
A lot of the Tesla unit's were thrown on the market without testing for the us market, so I sent my unit so they could get it right.they worked with me to get a good product out to the us market. Off course not everything is not perfect with aftermarket radios
Heres the link but you have to let the page load and theres a tab witch says color click on that a few time and the drop down will show it ...its very slow so you have to do it a few times
https://www.phoenixautomotiveinc.com...18502098976825
i dont think they no how much this amp is worth
so we will keep quiet about it
you have to see it in the car before you judge. Anything is better than the original unit , i bought the the first unit for $500 whitch was garbage ,this unit works and im happy with it ,i would PAY that money again not to have headaches like the others do...if your looking for home tv THIS IS NOT IT ! when i serviced my car with LEXUS 3 mechanics came to me asking about the unit, its impressive in every way
if you have the resolution to high it will lag ,black out and run like **** 1280x768 is perfect
