Window Track Molding/Trim Replacement Suggestion
Anyone have a part number I could search for to get replacement window sill molding/trim/weather stripping? Not sure what this specific one is called so I'm having a lot of trouble searching for it. It's the piece that one clips into the inside of the window and the other is a separate piece that clips into the outside of the window (clips to the door) and offers padding and a soft surface for the window to go up and down. I believe it has two lips on both sides.
2 hours labor is ridiculous? You understand thats very tedious work, and the potential for collateral damage is high right? It sounds cheap to me for banging out rivets on a fragile luxury car trim piece. Maybe you are just cheap
phoenixm3
09-14-03 06:15 PM
