Rear bearing Replacement ABS removal
Hi
Before I replace my rear wheel hub bearing, I remember how difficult it is to remove the abs sensor without breaking the plastic. My question is do I really need to remove the abs sensor before I replace the hub bearing? Looking at the new hub assembly, it looks like the sensor should not interfere when I pull out the hub assembly??? Thanks!
NoUltimatu
01-13-15 01:49 PM
