2008 gs350 Mark Levinson wiring
can someone tell me which is the amp remote turn on signal wire please!!
Hi I’m looking for the wiring diagram for the ML system in 2008 gs350 . I have searched online and on this forums but the ones posted. The wire color coding is different than mine Mine has only 2 wires to the sub one pink and one purple , I’m looking for the wiring color code so I can work on my system and do some upgrades here are pics of my amps pigtail wiring harness and the sub connector . If anyone can assist me and provide the wiring diagram or color code I’d for wires ie speakers, remote ,signal , sub . I would greatly appreciate , ( I did look at wiring file choke had posted but it seems to be different than the wiring in mine ) thanks in advanced
no one has any diagrams or info on this. The ones I have found color of wires are different from the plugs in my amp and my sub only has 2 wires and one voice coil? *♂️
Yes thank you very much, now the only wire I still need help figuring out is which wire (color) on the ML amp is the remote signal turn on wire . If anyone could help me with that info I will greatly appreciate it
I have the same issue as you do on my 2011 gs350. My amp wiring does not have any "key-on" remote, or turn on. Nor did it have that magical orange wire everyone else seemed to have. I was able to find an "accessory" wire by looking up wiring for a remote start function. It is a green wire located behind your glove box, against the side of the firewall. I did verify that it is only with the key in the "on" position.
Thank you so very much I will look into that tomorrow during the day ,do you happen to have a pic of the wire you are referring to? and I agree I looked for an orange wire and no luck so hopefully my 08 has that same green wire . I’m very thankful to you for sharing that knowledge bit I will let you know once I look into it
I no longer have the pic that crutchfield sent me. They did say they found it by looking up a remote start install. The green wire is located on the metal box that is mounted against the side firewall, closest to where your right foot would be if sitting in the passenger seat. It is a bit higher though. It is literally to the far right once you get glovebox removed. If looking at the back of the long, rectangular plug; the green wire is on the top row, just one or two wires out from the center of the plug. dont bother with the other three metal ecu type boxes. The one you are looking for is against the side firewall. Best of luck.
Nixsun79
12-12-14 09:44 PM
