What are the cons for AWD?
I'm in the market for a 3rd Gen GS350 and a couple I've come across for consideration have been AWD. I've been passing them up because I can't see the need for an AWD in Texas. To me it's just a potential for extra gas consumption and extra cost when things go wrong. Obviously I would prefer to not purchase an AWD but I'm trying to decide if all the other check boxes match up should I go ahead and look at a car with AWD. What is your opinion on AWD or not?
-Heavier
-Hurts weight distribution
-Penalty in MPG
-Increased long term maintenance (transfer case)
- The natural RWD balance as originally designed with these cars is somewhat compromised
-Not as "balanced" or fun to drive
-With a good driver and winter tires, it is absolutely not necessary under 99.9% of circumstances
-Penalty in MPG
-Heavier
-Penalty in MPG
-Penalty in MPG
Me personally I would avoid AWD with a passion because fundamentally you dont need it but at the end of the day my pick will be the car with the best drivetrain condition regardless of features or mileage. That would including standing behind the car while someone revs it to smell for any oil consumption, transmission shift quality, etc..
I own a awd! the negatives, they vibrate when you lower the suspension. Some vibrate on stock suspension, its a small vibration at idle. The gas difference between the two is so minor, I think its 1 mpg less then 2wd. You can do burn out!
The positive when it rains, this car is planted. Driving over sand or muddy, is no problem.
I didnt want an awd, but was offered a deal I couldnt refuse. So if you find a good deal on a clean one go for it, they are good cars.
no no no ive had the rear wheel and and AWD NO DIFFERENCE IN GAS MILLAGE ON MY WAY TO WORK . i cant drive the rear wheel when it snows it sucks even when i had snow tires on it ,water pump failed at 67,000 miles ,my AWD HAS 162,000 MILES ON IT AND I REPLACED ONLY THE BRAKE PADS AND ROTORS ,MY AWD HAS NEVER SEEN A MECHANIC, MY REAR WHEEL SUCKKKKKKKKKS
, IM TRYING TO SELL MY REAR WHEEL DRIVE GS, BUT NOBODY WANTS IT
Out of curiosity, what kind of gas mileage are you seeing between the two versions?
My experience with RWD in the snow has been not only reassuring but incredibly exciting to say the least. Granted it was a BMW 528i where you can turn traction control 100% off, but that car was planted as hell when equipped with winter tires - and a complete death trap without. The way you're able to effortlessly control rear axle angle with a delicate balance of throttle and steering application on a whim was satisfying and very exhilarating to say the least.
Ultimately your driving skill will go quite a long way - but only as far as your snow tires are willing to go.
I have a GS350 AWD and there is one really big drawback: if you have a flat and your tires are worn by more that 2/10 inch, I promise you that you are going to have to buy all new tires around or buy a new tire and get it shaved off. My wife has a Subaru AWD and we ran into this during the summer. She had a flat and we replaced it with a new tire, but the new tire really pulled, and we could tell the transmission/drive train not sounding right at all. She took the new tire to a dealer who shaved off about 20,000 miles and it was perfect after that. When I bought my four new tires at Discount Tire, I paid a couple of hundred extra for a lifetime warranty that if they can't put a new tire on my car without replacing them all, they will replace them all free.
Moisture (01-12-20)
I have heard this as well. It’s not about the tire brand, it’s about the AWD system. My mom had as to get 4 new tires on her Subaru because 1 was bad.
