Headlight Washer Nozzles for 06 GS430
Old 01-29-20 | 05:17 PM
mattr82's Avatar
mattr82
Default Headlight Washer Nozzles for 06 GS430
Hi all,
I recently purchased OEM 85208-30031 & 85207-30031, left and right headlight washer nozzle caps to replace the ones that fell off. I brought the car in today to my mechanic who said these don't fit a GS430, only a GS350+ (he actually has an 08 GS350 and it fit his vehicle perfectly). Does anyone know the correct/size model number for the replacement left and right washer caps for an 06 GS430 as every place I look, it appears the GS300/430/350+ all use the same washer caps.
Thanks in advance!
Matt
Old 01-29-20 | 05:23 PM
ibidu1's Avatar
ibidu1
From that part number it shows it fits your car, but why did you buy the whole sprayer system if all you needed was the chrome caps. They sell just the caps on ebay.
Idorablo (09-16-20)
Old 01-29-20 | 05:24 PM
ibidu1's Avatar
ibidu1
https://www.ebay.com/itm/Left-Right-...kAAOSwf-Bc47Xq
Old 01-29-20 | 05:28 PM
mattr82's Avatar
mattr82
I only bought the caps.
Old 01-29-20 | 05:29 PM
mattr82's Avatar
mattr82
https://www.ebay.com/itm/Pair-Headli...72.m2749.l2649
Old 01-29-20 | 05:39 PM
ibidu1's Avatar
ibidu1
That seller tricked you! First lexus doesnt sell just the washer covers, they sell the pump as a whole unit that includes the chrome tips. That part is not oem! Because both of those parts numbers combined they retail for over $500.00
Whats not fitting the shape of it? Or the black inside clip
Old 01-29-20 | 07:15 PM
mattr82's Avatar
mattr82
Damn! The shape of the actual cover. I brought it to an ex Lexus Master tech to look at and that's what he told me. I will just live with not having it, no way am I buying the entire assembly.
Old 01-30-20 | 12:17 AM
energie8's Avatar
energie8
I never use this feature, but when I do, it never works lol. Maybe the pump is broken or something on mine.
Old 01-30-20 | 02:34 AM
ibidu1's Avatar
ibidu1
Ya, that seller has a history of trying to pass off aftermarket as oem. If you read his history many have complained.
If only the tip is broken why not buy another chrome trim from another ebay seller. Try your luck as those things are pretty cheap. 8-$9 bucks a set shipped
Old 01-30-20 | 07:54 AM
mattr82's Avatar
mattr82
I believe the plastic piece inside is still functional. I just purchased the vehicle a few weeks ago and it didn't come with either chrome piece. All the cheap replacements I have seen have the same part number as the ones I purchased. I already contacted seller who asked if I wanted to keep the item and he refund half---haha no thanks! I did think it was odd that the outside looked OEMish with "Made in Japan,"/Toyota however the chrome pieces said "China" on the back, just like non-OEM ones.
Old 09-16-20 | 03:18 PM
Idorablo's Avatar
Idorablo
Default Just got mine off of Ebay
Hi all,
Thanks in advance!
Matt
Just got mine off of eBay and it works perfectly. Rather expensive $12 for probably a $0.50 piece. Pretty easy to put on grab some needle-nose pliers pull it out just have to be careful to make sure you put the nozzle in correctly and it should just snap right on 5 minutes max.
Old 10-22-20 | 07:35 PM
Mrbungle11's Avatar
Mrbungle11
hello sir!!
where did you get that item do you have a link if that’s possible??
i got one off eBay and doesn’t fit from side to side not flush like the other headlight !
many thanks!!
Old 10-23-20 | 07:08 AM
Idorablo's Avatar
Idorablo
Default Nozzle caps
Hi all,
Thanks in advance!
Matt
https://www.ebay.com/itm/Headlight-W....c100005.m1851
Old 10-23-20 | 07:09 AM
Idorablo's Avatar
Idorablo
This is where I got mine.
https://www.ebay.com/itm/2-pcs-L-R-H....c100005.m1851
Old 10-23-20 | 07:10 AM
Idorablo's Avatar
Idorablo
e-man
05-17-12 10:11 PM
JHStrange
08-02-05 06:39 PM
