LED DRL Headlights on the GS
I have these eBay headlights for about a year now. They look great, however, you do lose the AFS feature. You'll get the flashing AFS off light if you don't remove the fuse. I also noticed that the light beam itself doesn't go as wide as stock. It mostly just projects the light straight. The chrome bezel also is very cheap. It feels flimsy and the weather stripping always falls off. I ended up putting the stock chrome bezel back on. As for the DRLs, it still uses the high beams at half the voltage. It uses a completely different bulb(H1) compared to stock (9005). I didn't like the yellow look of the halogens so I put LEDs and wired the lights directly to the battery. If you don't, the lights will flicker like mad. The DRL is basically running at full power and is extremely bright at night. Might even be brighter than my low beams. I used 8000k RCP HIDS as low beams and they surprising match my LED fogs perfectly.
Stock Lights
Tried on yellow fog lights.
Low beams
DRLs + Parking lights
DRLs
Stock Lights
Low beams
DRLs
User 122922 (07-21-22)
If you're talking about the OEM headlights, it should be at its default height when the car is shut off or when you're driving without an incline. If you remove the fuse the AFS doesn't cycle up and down when you start up the car since you've disabled it. Basically, it shouldn't affect the height.
Link to the ebay vendor? Also, is the overall light output comparable to OEM? my right headlamp needs replacing and prices are still in the $450+ for a decent used one on ebay/car-part.com
If I were to do it again I would do an oem headlight, I must have purchased from a not so great company.
Are you sure the DRL are the high beams run at half the voltage? I'm pretty sure there are 194 bulbs in the same housing serving that purpose and the 9005 bulb was off. I'll check.
I'm in the process of replacing the headlights too. I already read Chinese headlights reviews and they're mostly bad. I decided to go OEM. New or used I don't know now. I wanted to buy them from OELighting, which sells them incredibly cheap, but all headlights are out of stock since several months. I don't know if they went out of business, I sent them an e-mail and no response to date. And I checked used ones, only to find them with broken tabs, water penetration or faded lenses. So I may go to the dealer but God I gotta be obsessed with having a car that illuminates well to pay them the fortune they ask for. Will see.
Compared to OEM, these are not as effective, and they lack the AFS feature. As for the DRLs, it uses the high beam bulbs (9005) at half the voltage. This gives the bulbs the ugly dim yellow color. The 194 bulbs at the corner of the high beam housing serve as the parking lights. They come on with the headlights or when you switch on the parking lights. These headlights replace the parking lights with the led strips. It also still uses the same high beam bulbs at half voltage.
Yes, it requires that you reuse the OEM ballast. In my case, the ballast was never replaced, so the connector part wouldn't fit through the stock headlights. I had to cut the wires in order for it to come out.
Headlight issues
I hope I’m posting on the right thread. I’m having headlight issues. Not sure if it’s just bulbs or bad ballast possibly. My running lights work but when I turn my headlights on the driver side goes out, when I turn my high beams on, it comes back on, and also my driver side main headlight goes out on one setting as well, as you can see in the pics the driver side headlight is more of a blueish color as well. I’m not sure what’s up with them.. anyone had similar issues? I appreciate all feedback!
Blueish color on driver side
The one setting, see passenger on but driver off
Normal daytime running lights
Bright lights on
Bright lights on
A purple HID bulb is just a sign of a burnt bulb. More rarely, they can turn yellow, as on your passenger side. Your driver side marker bulb must just be dead, so you just need to replace the bulbs
Bright lights on
Bright lights on
