2008 GS350 Speakers
I have a 2008 GS350 and I have about 3-4 speakers blown. The car has the Mark Levinson sound system package. If I wanted to change all the speakers in the car, what are my options?
Also, does any have instructions or video on how to remove all the speakers?
Door speakers and the front speakers are easy to replace. But the rear ones are b1tch. I didnt remove/replace them but i have a blown speaker on my previous camry and to replace the speaker the seats have to be taken off and lot of trim pieces and screws gosh. Good luck with it or else you can go to an audio shop and they will do it for you XD
I have a blown ML sub and the right front dash speaker has making noise. found the dash speaker the dust cap came off so I glued it back on with some Gorilla Glue to put it back on, sounds good now. The ML sub I'm thinking of adding a Pioneer TS-A2500LS4 shallow sub. from the specs I found it seems like I can modify the ML sub cage and screw the Pioneer and should fit perfect plus it should be a freeair sub so I'm expecting it to sound good.
aznaznazn
03-06-17 03:49 PM
