2006 GS300 oxygen sensor part number
Hello,
I have to replace the B2S2 sensor (code P0057). I came across 2 possibilities : 8946530720 and 8946530710.
The thing is the second part is noticeably less expensive, but I don't know if it fits. The first says "left" in the description, the second says "left, right". So does the second one fit? But then why make a different part for the two sides if a single part is compatible with both? I don't know if there is an error, but they won't answer my e-mails.
Thank you
Thank you
OK, I didn't think to check Rockauto. I checked Autozone, but they only gave the Denso part number. So the one ending with 710 likely won't fit. Thank you, I'll order the other one
MIKEY19625
11-24-16 01:12 PM
