Soo i hooked you some music in my car everything was working just fine up until yesterday now while I was driving my touch screen went black the ac was still running but the music stopped playing so while I was driving home as I got to my house all these lights on the dash started coming on so I turned the car off I opened the hood and I noticed that the fusible link was popped now last time this happened it was because my alternator went back so I had a new alternator and battery put in this was two months ago so I’m guessing it popped now because of the beat I put in maybe it was to much on the alternator so I replaced the link again and those lights went off but the screen is still black I even took out the beat I’ve checked all the fuses none were bad I unhooked the battery while the car was running to see if maybe the alternator was bad but nope it stayed running and I’m sure it’s not the battery because the aalternator charges that so my question is what else can it be my ac doesn’t work nothing around or in the touchscreen works but my radio turns on I just can’t see anything it’s 110 out here there’s no way I’m going out without my ac can anyone help
Soo i hookedyou some music in my car everything was working just fine up until yesterday now while I was driving my touch screen went black the ac was still running but the music stopped playing so while I was driving home as I got to my house all these lights on the dash started coming on so I turned the car off I opened the hood and I noticed that the fusible link was popped now last time this happened it was because my alternator went back so I had a new alternator and battery put in this was two months ago so I’m guessing it popped now because of the beat I put in maybe it was to much on the alternator so I replaced the link again and those lights went off but the screen is still black I even took out the beat I’ve checked all the fuses none were bad I unhooked the battery while the car was running to see if maybe the alternator was bad but nope it stayed running and I’m sure it’s not the battery because the aalternator charges that so my question is what else can it be my ac doesn’t work nothing around or in the touchscreen works but my radio turns on I just can’t see anything it’s 110 out here there’s no way I’m going out without my ac can anyone help
Holy run-on sentence, Batman!
Go ahead and repost this in it's own topic as it's different from what the OP is reporting.
I would look for loose connections on the high-current wires -- alternator, starter relay, battery, ground straps, etc.
