Moonroof open button sometimes doesn’t work
2006 GS430, 175k miles.
A few weeks ago I noticed that the moonroof wasn’t opening when I pushed the button. Sometimes it would take 2-3 times for the power to engage. As of today, I can still open it, but I have to push the button fairly hard. No issues at all with closing or titling it, so it’s definitely the button and not the motor.
Any suggestions as to what I can to to address this? I assume it will get to the point where one day I won’t be able to open it.
Thanks much.
e
Thanks much.
e
In any event, I was poking around on eBay last night and it looks like the overhead console is pretty cheap to replace, so when it eventually goes out I will probably just replace that entire panel. It looks like those consoles can be had for less than $50. Thanks for your help.
By the way, I don’t know if I updated you on the leak, but I determined that it was coming from the moon roof channel. You were right that there must’ve been some pinhole or something that I couldn’t see that was letting water in. I basically lined the channel with black gorilla tape and that stopped the leak.
