Climate Control Not Working! please Help!
Hello, I have a 2006 lexus Gs300 AWD and the climate control doesnt work. There is no air coming out anywhere and the screen is stuck on the Trip Data page. I just bought it like this and am wondering if anyone else has had this problem and what the fix was. I dont know if it has a climate control Screen, but this is my first lexus so Im wanting to have it right soon. Are there any test I can do to find where the problem area is? Another thing to note is that the power windows, except for the driver, dont work, at least from the drivers hand rest, I haven't checked from there respective switches. Any Help Is greatly Appreciated!
The air output and fan speed are set through the climate menu in the screen, yes, looks like yours is broken... But you can still put it on auto mode with the auto button and set the temperatures with the temperature buttons next to the screen. As for the screen itself, it could just be a bad digitizer. I think it is replaceable (some people did it there).
Regarding the windows, it looks like the driver door doesn't reach the other doors' ECUs, but to diagnose this efficiently i.e. not testing things randomly for years without knowing whether you're on the way to achieve it or not, you would need the Techstream software or to have it scanned at a dealership.
OK, this is what made me believe the screen wasn't responding, but yes, there are cases of unresponsive buttons too. I don't remember what to do in this case, I hope other affected people will chime in. But instinctively, solutions could be have a pro disassemble the unit and repair the buttons or replace the unit with a used one, what I think people here have done (it costs between 5 and 10 grand new at the dealer...).
Remove the radio/screen assembly and inspect the wires in the back. It possible a loose plug, or corroded pins. If no luck, you can replace the whole unit with a used one or send it off to get repaired.
Im a firm believer in that if I have electronic issues, I like to take things apart myself. You never know sometimes you get lucky and find something so minor that can be easily fixed. The assembly is super easy, you can take it apart yourself. There are videos on youtube that show how to remove it out from the car.
1.)Any specific fuse or connector that has control of those the panel and might throw those codes
2.) Where can I find a decent wiring diagram, even if I have to cross reference three.
3.)I ordered a new HU Of eBay, but for anyone else having this problem and put in a new battery/disconnected the battery, please, For the love of god, Do the battery cable “fix” its worth the 35 minutes of your time to try it before you go chasing things that might end up messing things up more
Any help greatly appreciated
P.S. My I took how simple My Infiniti M35 is for granted, same features as this Gs and way quicker, hopefully this car works out tho
Test the power supply on the harness that attaches to the back of the radio and hvac. Maybe its best to print out a wiring diagram of the plugs to see what is positive and what is ground. If its getting power then the radio is at fault, if its not then its in the wiring or fuse box.
These cars are solid, but you did purchase a 2006. The first year had the issues, its not as fast nor does it brake as good as the 07-up GS350's. They are the more desired ones to buy
johnbot123
SC- 1st Gen (1992-2000)
11-18-08 08:52 AM
