GS460 Camshaft Sensor and O2 Codes
As most of you know, this car has been a total headache since I’ve gotten it. After slowly working out all the issues, I figured I’d be in the clear, but.. no.. anyways.
These codes showed up last week. I cleared them as I thought they were a fluke, but they have returned. I decided to not drive it to work today. Codes are below. Any and all help is highly appreciated.
P1360 A Camshaft position actuator circuit open low high bank 1
p1361 A camshaft position actuator circuit open bank low high bank 2
P1364 C camshaft position actuator circuit open low high bank 1
P1365 C camshaft position actuator circuit open low high bank 2
P0031 Heated O2 heater control circuit low bank 1 sensor 1
P0051 Heated O2 heater control circuit low bank 2 sensor 1
only recent work that was done to it was the belt tensioner, but all sensors and connectors were reconnected. This was done about 3 weeks ago.
I would look into that, the VVT solenoids, and the camshaft actuator itself.
I got a camshaft position sensor code before and I just replaced the sensor and it went away. Sometimes it'd come back for a day but i'm pretty sure it's because the engine burns oil and throws off the sensors occasionally. Did a piston soak with Berrymans and a ton of carbon came out, haven't gotten a code like that since.
mmlex1987
12
12-24-09 08:51 AM
